For Sale Soarer - 1JZ, R154, 500BHP - Project 90%
Thread in 'Drift cars for sale' started by e_dale2000, Feb 11, 2019.
  1. e_dale2000
    e_dale2000 Member
    Manchester
    I've been building this slowly as a second car but no longer need it. It is a project still but almost complete it just needs a little time and it will be amazing. I will list all work needed below. The shell is an ex BDC shell which i believe was Ricky Emerys. The front slam panel had been damaged so the one from my donar car was swapped on. The rear quater has had a tap but its hidden behind the bumper and doesnt effect anything. This is a super clean shell as most toyotas appear to be compared with nissans...
    The good stuff!
    Caged Soarer with nascar style door bars, freshly painted in metallic black. Fibreglass rear quarters, custom wider front quarters. All glass refitted. doors chopped to accomodate nascar bars and windows open a fist width. boot lid light weightened and fitted with quick latches. The dash is mostly painted black, the heater controls are there(which work) along with the heaters, AC has been removed.
    1JZ non VVTi engine from my previously running soarer.
    Inlet modified to blank off Idle controller and 350Z throttle body fitted to allow DBW
    R154 Gearbox with R154 to JZ bellhousing
    Exedy Hyper Twin clutch (only done about 1k as it came out of my skyline which i purchased new)
    IS200 clutch pedal and master cylinder its been made to fit and works.
    Japspeed 3MM thick manifold - New
    45MM Turbosmart wastegate - New
    Borgwarner EFR 7670 - (Need to confirm model) refurbed and ran once, ive had the internal gate welded up
    New stainless overbraid turbo lines(waiting on water lines turning up)
    Japspeed Radiator - New
    Front Mount intercooler setup and pipe work.
    Supra 550cc Injectors flow checked and cleaned
    Custom 3inch turbo back exhaust system.
    Polybushed subframe and welded diff.
    Japspeed Front Camber Arms (New)
    Custom Cusco/GAB coilovers.
    Chopped hubs
    LS400 Brake calipers and discs
    Walbro 255 - New
    Deep dish OMP wheel ( i think its a rep) and boss
    The to do list / bad bits
    Needs a pair of bucket seats/harnesses
    DBW pedal - comes with it but needs mounting/fitting.
    It needs an ECU - (I have a new Link G4+ to be sold seperatly)
    wiring finished to suit ECU
    Needs a hydo and fitting.
    Brake lines sorting
    Bottom arm ball joints are warn.
    The drivers rear quater windows shattered after being fitted, i have left it in but it will need replacing. (currently held together with the tint.)
    A bit of tlc to make it how you want it.
    I have no V5 for this vehicle i tried to apply but they said it needed taking for an MOT test first before getting one. Comes with one key for the barrel and doors. I've been honest with the advert as i dont want someone to come down and be disappointed or see something thats not as described.
    I've a load of spares that can go with it, looms, lights, suspension arms etc for the asking amount
    Comes on a set of crap nissan rims
    Price wise im looking for £7000ono
    Car located in manchester/warrington area. Can be viewed most week nights and weekends. Delivery possible if we come to an agreement.
    I will get some better pics but here are some to get you going.
    IMG-20181108-WA0002. 20150518_125521. IMG-20181108-WA0001. IMG-20181108-WA0000. 20180707_180052. 20180417_194517. 20180417_194503. 20180417_194453. 20180417_194447. 20180417_194435. 20170723_183635. 20170716_171453.
    #1 e_dale2000, Feb 11, 2019
  2. Retz
    Retz Member
    Birmingham
    Nice spec u got a price in mind?
  3. Gazelle
    Gazelle Active Member
    Essex
  4. e_dale2000
    e_dale2000 Member
    Manchester
    thanks maybe i should make it a little clearer.
  5. e_dale2000
    e_dale2000 Member
    Manchester
    as in the add looking around 9.5K
    i will edit the post so its a little clearer and get some newer pics.
  6. e_dale2000
    e_dale2000 Member
    Manchester
    bump for price drop, open to offers will come with everything i have for it bar link ECU, if you want to do a deal on the lot i will.
  7. Muscles
    Muscles Member
    Pm me your number.
