Soarer modified hub knuckles. I make these my self and have tried and tested them on my own car with very good results. They have been shorted 25mm and dropped by 15mm to give better alignment of the steering arms. Basically a bolt on lock mod £100
Do you have to remove the ARB to run these, or will stock wheels run ok without fowling on full lock?
No I run these with the roll bar still fitted and stock wheels should be fine. If you fit rack spacers then you might have to run extended upper and lower arms to give more clearance but just the hubs alone gave my car more than enough lock.
