For sale is my S13, I have had this car for around 6 Months. During this time I have only taken it to 1 drift night. The car is great to drift and is great for learning or gaining more experiance drifting. The car pulls great with no knocks or grinds from the gear box. Since I have had it ive only run it on Shell V-Power. The reason for selling this car is that I am going to uni in september and will not be able to afford to run it while I am there. Then engine has approx 90k miles and the shell has approx 137k miles. MOT until 16/06/2019. Blacktop straight cam SR20 with around 290hp (Not Dyno'd) Stage 1 Chip 12 - 14psi of boost Turbo Timer Tein Coilovers on the front/eBay coilovers on the back Front Adjustable camber Arms Steering lock kit Driftworks Rear Camber arms XXR 527 17x9.75 et0 (Damage on one wheel as pictured but still holds air) 25mm hubcentric spacers 20mm or 25mm (Unsure which) rear overfenders Rocketbunny style ducktail wing Full decat exhaust system unsure what brand Front and Rear Strut braces Drivers Driftworks bucket seat with lowered rail Passenger Bride reclinable bucketseat Genuine OMP corsica steering wheel Handbrake drift button Knockoff Takata Harnesses All the rear is striped out so no backseats or carpet in the back Boost gauge and oil pressure gauge (Oil pressure not wired up) New water pump fitted New starter motor fitted Welded Diff I cant remember much else of the top of my head but if you want to know something ill find it out! Now onto the bad parts: Theres a bit of rust on it which is expected from a 25yr old car, there is some rust around the arches and on the sills. The drivers side windscreen wiper is tempermental, sometimes works sometimes doesnt, I think it is just a loose connection on the motor Only the passanger door speaker works but you can still hear music clearly. Front wheels rub on the arches on near full lock Front brake pads are low but I have some new ones to put on, Will be replaced before sale of car Paint work isnt the best Got an exhaust blow (Depending on how quick the sale is I may have fixed it) Car will come with another set of wheels for drifting (17x8 i think), an oil catch can and someother misc parts. I am looking to either get £4500 ono or a part exchange with money my way for a clean BMW e36 or something similar which id be able to insure. {} {} {} {} {} {} {} {} {} {} {} {}
