Sr20 big turbo build
Thread in 'Technical Questions' started by kyle_h95, Mar 14, 2019.
  1. kyle_h95
    kyle_h95 Member
    Hertfordshire
    Right, I'll try make this as quick /simple as I possibly can!
    Bought a hks t04z turbo kit from a friend to use for when I build an engine which can take what I throw at it; have always planned on forging the spare engine I have got but not quite to take the power I'm now looking at running.
    So the turbo is aparently rated to 720hp, but I'm looking more around the 5/550 sort of mark.
    I'm looking at a parts list and was wondering what sort of things will be restrictive at that sort of power.
    Main things I'd like to know are
    -what cc injectors?
    -will the standard fuel rail hack it?
    -inlet manifold, will I need a plenum?
    -headgasket, how thick?
    -Will an8 fuel lines on a Bosch 044 pump(from swirl pot) be enough flow?
    My list for the build so far is-
    Manley forged rods
    Cp Carrillo pistons
    Hks cams
    Arp headbolts
    Arp main studs
    ACL mains
    Genuine chain kit
    Genuine gasket set (no h/gasket)
    Genuine oil pump
    Oversized/baffled sump.
    Any info any one has I'll soak It up
    Thanks!
