SR20 Mk2 Escort
Thread in 'Project Cars and Builds Threads' started by retro-ed, Sep 14, 2011.
  1. Srs_721
    Srs_721 Member
    Witham, Essex
    Top work as always man!
  2. retro-ed
    retro-ed Flicks 'n' Kicks
    Hinckley
  3. essexcapri25
    essexcapri25 Member
    whistable, kent
    how have you gained so much lock?
  4. retro-ed
    Hinckley
    Modified rack and shortened steering arms. Not as much lock as S bodies with Geomasters/wisefab etc.. but it is great. There are pics and info in the thread :thumbs:
    few video clips at 0:37, 0:50 and cool entry at 1:37.....
    Have done a tiny bit more mapping at the weekend on the road. Managed to get the full throttle AFRs much better. It is quite jittery as was struggling for traction over some of the bumps.
    338hp/318lb.ft...More to come up top but getting there :cool:
    Here is a roll on from 2000rpm in 3rd until the limiter in 4th (fully dry tarmac) you can see how savage it is now :cool:
    And again but after some proper heat in the tyres so less spinning..
    Moving house next month so that will take up allot of time. Next thing for the car are a few MOT style jobs and keep using it as much as possible!
  5. retro-ed
    Hinckley
    A vid of earlier in the day having a mess around...
    small wall rub at 1:26
  6. retro-ed
    Hinckley
    Since Buxton............
    Did some more mapping. Now at 1.1bar peak and it is loving it...
    Got an MOT
    Washed it....
  7. retro-ed
    Hinckley
    Been mega busy over the past month moving house but managed to get out last weekend at one of my personal favourite events of the year; RS Combe. As previous years I got to take part in the drift demos and also get a bit of grip driving in. Combe full circuit is probably the fastest place in the UK you can drift so a great opportunity.
    Car was only running 0.5-0.8 bar of boost but was still awesome. In the grip sessions it stayed with pretty much everything and in the drift sessions it was brilliant.
    Couple of highlights for me was getting a 5th gear, full throttle flick entry into Avon rise done (which is around 120-130mph), then messing around with some backwards entry attempts at other corners on the circuit. Here is a good one coming into quarry...
    Nothing broke and he car was spot on all day. It received record amounts of hate from the Ford purists which is always amusing.
    Rear arches / quarters took another pasting due to exploding tyres..
    I used it for work on Monday to check it was all driving sweet. Next thing is to start on is developing a new rear axle setup to replace the vulnerable English unit. I still haven't broken a shaft but have worn out quite a few CWPs now and am getting sick of the whining! I am just finalising the bracket designs then will get them laser cut next week. I have no garage facilities at the mo so any work it needs over the next few months will be back on the driveway…
    Next event is some more demos, this time at Silverstone for Ford Fair.
  8. essexcapri25
    essexcapri25 Member
    whistable, kent
    What you doing with the axle. Keeping it English?
  9. mattc
    mattc Member
    West Brom
    Whats the hate for?
    Nissan Engine?
  10. Stavros
    Stavros Active Member
    Isle of bollocks
    Knowing most the Ford saddos these days, for the engine, for actually using the car rather than polishing it and telling everyone how fast it is despite never using it, for drifting, for actually having some driving talent, for pretty much everything.
  11. mattc
    mattc Member
    West Brom
    Same in every car "scene" then
  12. robrs2
    robrs2 Active Member
    Teesside
    The english is fine within limits. If your after fitting 15x10" wheels you'd kill it. Best thing is to fit some 3J shafts
  13. retro-ed
    Hinckley
    It is the CWP that is the issue. Under fast road use/moderate track, they are fine but as soon as you do the big track, fast stuff it just eats itself. This is common accross all of us drifting with English axles. It never actually breaks the gears, just mashes the contact face of the gears giving lots of backlash, therefore whine.
    I dont see the point in spending loads of money on posh shafts when the weakest link is the CWP size. I have never broken a standard shaft to this day on this car and have seen lots of people break posh 2 peice items. For the cost of those posh shafts I will have a whole new axle in there that will take the punishment easy peasy ;)
  14. robrs2
    Teesside
    Do you still have the crush spacer? The diffs are much better with a solid spacer.
    Don't forget it's only a small diff, something like 6 or 6 1/2".
    I have been looking to find a third member set from another source. Toyota pickups are one and the mx5 also looks possible to build an axle from.
  15. essexcapri25
    essexcapri25 Member
    whistable, kent
    How could you use mx5. That has irs not a live axle
  16. retro-ed
    Hinckley
    Yep still using a standard style crush spacer and measured preload of the pinion before and after one got toasted and it didn't seem to looose much. The problem just seems to be it munches the crownwheel after proper sustained abuse but as you say, it is only really a diddy thing so is to be expected really. Next axle is a Volvo item and is bigger in every way so should make it bulletproof.
    Got the chance to do the drift demos at Ford Fair again this year. As usuall, was great fun having access to the full national circuit. This allowed entry speeds from 120 - 130mph which was great fun. Track had some really horrible slidey bits which must have been some oil or something so there were alot of near misses from everyone but for once everyone survived without breaking their cars!
    Couple of pics until GoPro is downloaded...
  17. retro-ed
    Hinckley
    Just started going through the videos and found this near miss that I forgot about... Changed up into 4th and.... oh shiiiit
    Will upload some vids over the next few days. The driving was a bit more on the wild side this year so was pushing the entry speeds and droppig lots of dirt and kerbs! Fastest entry speed was top of 5th so 130mph+ :smokin:
  18. driftdog
    driftdog Member
    stoke on trent
    much love for this car :-)
    - - - Updated - - -
  19. retro-ed
    Hinckley
    5th Gear into Copse :smokin:
  20. Tomptr
    Tomptr New Member
    Absolute favorite Escort of all time!!
    Epic skills as well mate,be it fabrication,driving,everything!
    Those top mounts are just sublime!
    Keep it up!
