walton fabrications sr20det exhaust maifold 650 pounds ( 5000 miles from new ) {} {} {} {} {} {} {} holset hx52 with 16cm hot side 250 pounds 0 playing ( the left side is the one for sale ) {} Ca18det 6 boost exhaust manifold 3mm tick turbo foward above ps 450 pounds {} sr20det notch and red top for parts including sr20 red top 2.2l stroker parts {} {} Owen developments garrett htagt2871r 750 pounds 5000miles from new ( tial rear housing v band . 64 alone is 300 pounds )lines can be included for Extra price all plug and play for sr20det down pipe also available for extra price {} {} {} Sr20det intake plenum manifold mint condition come with Fuel rail , but no tb 350 pounds ( has the injector plugs for oem side feed or afther market injectors ) {} 1050cc asnu injectors all flowing perfect just missing one O ring seal 300 pounds (plug and play for the sr20det intake plenum and many other rails ) {} Nissan skyline gtst rb25det complete running gear for sale with 5 speed manual gearbox engine runs very well can be seen running prior engine removal , full engine , gearbox , ecu plus engine loom 1800 pounds ( the shell will be used for my 2jz 700bhp set up ready to go in ) {} {} Ca18det stock crank in mint condition 250 pounds oem size Ca18det .25 regrounded fresh never been used afther grounding 190 pounds {} Ca18det refurbished cylinder head 250 pounds Ca18det ported cylinder head to flow 600bhp plus 650 pounds {} {} All items can be inspected prior to br brought , collected/posted as u want Payments if posted paypal only Collected can be inspected and cash only I still have lots of other bits that I didn't get arround to take pics and add like Sr20det os giken twin plate clutch with mint discs 650 pounds Sr20det lightned flywheel 60 pounds Sr20 single padle clutch 100 pounds Sr20det s14 block with oem caps 240 pounds Sr20det non red top hks cams 250 pounds Sr20det top mount elbow in a pic above 80 pounds at home for fast response call me or txt me on 07397761766 ALL ITEMS CAN BE COLLECTED FROM LITTLE KINGS HILL , my workshop
Could you give some more details on the owen developments 28 71r , is it a gen 2 what power did you get on straight cam sr20det ?
sorry for the late replay , just been sold today , it did make 455 or 465bhp at 1.2 bars of boost with a 2.3l strocker engine that i still have for sale , the engine is getting a new 90mm darton sleeves fitted to it then i will sell it as complete engine that also has hks cams and hks rocker stopers
