sr20det BMW e30
Thread in 'Drift cars for sale' started by Tomae86, Oct 1, 2013.
  1. Tomae86
    Tomae86 Member
    For sale is my 1988 BMW e30 325se with sr20det engine.
    Spec list:
    Sr20det engine + gearbox.
    Custom engine and gearbox mounts made by Slidemotorsport.
    Custom propshaft.
    Paddle clutch.
    Uprated fuel pump.
    Hks adjustable actuator set to 0.85 bar.
    T28 turbo with braided oil/water lines.
    Apex s14 alloy rad with custom stainless cowling.
    Standard manifold with custom stainless heat shields.
    3 inch turbo elbow to full stainless custom twin exhaust for maximum ground clearance.
    FMIC with full alloy hard pipe.
    Wire tuck with fuse box moved to glovebox.
    S14 brake servo+master cylinder.
    Body;
    Full adjustable BC coilovers.
    Adjustable eibach anti roll bars font + rear.
    E46 steering rack (its the 067 part number quickest e46 rack) with customn linkage, e34 uj's and extra lock spacers.
    Custom PAS linesRear beam and trailing arms polybushed.
    Front essentric polybushes.
    16x8 rota grid wheels with new Nankang tyres.
    Front 15mm hubcentric spacers+ rear 20mm.
    Fully re-built limited slip diff by a renowned member on e30zone (locks up very well).
    WMS larger front brakes with braided lines and ebc red pads.
    Rear drilled+groves discs.
    DW hydraulic handbrake.
    ABS removed.
    New fuel tank+lines.
    Flared front+ rear arches.
    Full repray in diamond black with colour coded bumpers.
    Custom front valance.Angel eye headlights.
    Interior;
    Rear stripped with sound deadening removed.
    Half cage.
    K-sport drivers bucket seat.
    Omp rep dished steering wheel.
    JVC 12 disc multichanger.
    Rear pop out windows.
    Boost gauge.
    Toad Alarm/immobiliser with remote locking.
    I've owned the car since Jan 2009, I did the bodywork and had it sprayed about 3 years ago then approx a year ago it went to Slidemotorsport for the sr20 conversion. Since then it's been my daily driver and done 1 drift day at Teesside in which it has been faultless.
    Bad points;
    To be really picky there are a few scratches and stone chips on the car, a slight bit of surface rust on the sills and front arch where wheel has caught it.
    Slight whine from clutch release bearing.Slight knocking noise from rear which I believe to be from some play in the driveshafts as all bushes are pretty new poly bushes, prop and bearing new last year and lsd is rebuilt.
    Remote locking only locks the doors but have to use key to open.
    Could ideally do with a swirl pot for drifting as when i did teesside drift day there was some fuel starvation when the car was below half a tank of fuel. Driving as a daily its been fine.
    Car has had some welding done (foot wells / bulkhead / inner rear arches/rear valance) all to a high standard and is now 100% solid.
    Mileage on the car is 162,310 but as you can see from the spec most parts have been changed or renewed.
    Unfortunately have to sell up to help fund a house deposit so im not interested in any p/x's unless its with a cheap (around 1k) economical daily.
    MOT: 01-03-14
    Tax: 20-02-14
    £5250ono
    [​IMG][/URL][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    [/COLOR]
    #1 Tomae86, Oct 1, 2013
  2. m@t
    m@t Member
    Change the text colour
  3. Tomae86
    Tomae86 Member
    didnt realise it was going to come out black..... should be sorted now anyway
  4. magicmat
    magicmat Active Member
    I've seen this car and its totally mint, photos dont do it justice at all.
  5. Tomae86
    Tomae86 Member
    Just been to Slidemotorsport and had both new turbo gaskets and also oil + filter change.
    Forgot to mention still have all the rear interior so could all go back in if wanted.
  6. Tomae86
    Tomae86 Member
  7. LewiS14a
    LewiS14a Member
  8. Tomae86
    Tomae86 Member
    Bump!!!!!
  9. Wackojacko.
    Wackojacko. Member
    This is my perfect car ! Just bought a fucking house though. If only this had been up forsale a few months ago. GLWS.
  10. Tomae86
    Tomae86 Member
  11. Clive Thomas
    Clive Thomas New Member
    It's been awhile since the post but If you don't mind saying what brake servo have you fitted?
  12. Evo_ac
    Evo_ac Member
    Very nice this. If I sell my E36 I'll be in contact. Where are you and I take it mot should be 18 not 14
  13. BreadBin
    BreadBin Rough Tonguer
    Thread is 4 years old...
