Sr20det, gearbox conversion, turbo set up
Thread in 'Parts for sale' started by g7gno, Oct 25, 2022.
  1. g7gno
    g7gno Member
    Sr21det Z32 pistons Trust cams MLS gasket nismo 550 Apw mid mount waistgate priority full v band Puslar gtx2871r tial .64 rear stainless housing Gfb 38mm waistgate, Manifold, turbo, wastgate only done Dyno and maybe 300miles Gs6-53dz box Pmc box adapter Sachs clutch Full BMW probshaft modified Custom gearbox mount Shifter Been in car around 2 year and only done a hand full of track days
    Can go with rom and z32 maf hks gtrs turbo was 400ps when build and bought from power vehicles as it's currently on ECU master black that I plan on keeping however if someone needed full set up I can supply aswell
    full turbo set up £1500
    Full gearbox and conversion package £1500
    Full Engine with other hks turbo manifold and hks gtrs turbo was sent to aet for rebuild decided agents it and bought the pulsar so turbo will need put back together, z32 maf, nismo 550 injectors rom 400ps, £3000
    Can supply s13 box and og giken twin plate clutch for above aswell price not sure talk to me,
    This is all still in the car and running for anyone needing to see it running,
    I can get more photos if needed
    Any questions call or message 07707181568
    IMG20221018211925. IMG20221018211459. IMG20221018211241.
  2. Soarermike91
    Soarermike91 Member
    How was that gearbox setup compared to stock box ratios??
    Also is it a straight fit or does it need a touch of massaging?
  3. g7gno
    g7gno Member
    I treated it like a dog box so pulling away in second and was ace but I had a 3.9 might have been better on a lower final drive,
    Yeah rubber hammer made easy work on the tunnel
  4. g7gno
    g7gno Member
    Turbo set up sold
  5. g7gno
    g7gno Member
    Box out some photos
    Gs6-53dz 6speed box
    Pmc adapter and flywheel
    Sachs clutch
    Clutch fork throw out bearing
    Uprated clutch fork pin
    Auto flex plate
    Full BMW propshaft modified to work
    Custom gearbox mount, linkage and shifter
    All Hardwear
    Full bolt in job for a s14
    Been in car for 2 year and done a handful of track days
    No longer needed can post anywhere at cost
    Call for any questions 07707181568
    IMG20221115193650.
    IMG20221115193719.
    IMG20221115193801.
    IMG20221115193810.
    IMG20221115193833.
    IMG20221115193845.
    IMG20221115195448.
    IMG20221115195454.
  6. g7gno
    g7gno Member
    Gearbox set up sold,
    Engine left witch I'm happy to keep I'll add photos when I get loom out car off all included
