SR20DET idle issue HELP!
Thread in 'Technical Questions' started by Just-James, Jul 29, 2015.
  1. Just-James
    Just-James Member
    Lymington, Hampshire
    Hi All
    Ive just fitted a horsham stage 3a setup to my 14a and I'm having some issues with making it run right.
    Ive Tried two MAF Sensors
    Ive Tried changing the metal intake pipe for an original
    Ive Tried two ECU's
    The turbo is brand new and the other parts are from running cars.
    Heres a video of what its doing:
    https://www.youtube.com/watch?v=VaX9h-rHEUA
    over fuelling and running like cack!
    Anyone experienced this or got any ideas?
    Thanks
    #1 Just-James, Jul 29, 2015
  2. FAbity6032
    FAbity6032 Member
    I can't see the video because it is private. Maybe have you tried contacting Horsham?
    Vacuum leak or broken turbo re-circulation valve? You don't have a BOV do you? Also Boost leaks low fuel pressure leaking injectors..... Throttle position sensor?
    #2 FAbity6032, Jul 29, 2015
  3. Just-James
    Just-James Member
    Should be made open to view now, it's going in to Horsham next month.. Just trying to get it running properly first!
  4. Just-James
    Just-James Member
    Its not got a bov, had a play with the tps to no avail!
  5. sukhy96
    sukhy96 Member
    Wolves
    Boost leak...
