SR20DET - Possible leak.
Thread in 'Technical Questions' started by toyo_, Feb 17, 2018.
  1. toyo_
    toyo_ Member
    Spain
  2. ard
    ard Member
    Lithuania
    leaking head gasket between head and front oil pump cover
  3. toyo_
    toyo_ Member
    Spain
    Thank you very much ARD for the answer, I will review it.
  4. toyo_
    toyo_ Member
    Spain
    IMG_2839.
    Its possible to be the front Crankshaft Oil Seal?
    13510-53J11
    Seal Oil Cranks
    Thanks!
  5. toyo_
    toyo_ Member
    Spain
    After a good cleaning and 2 trackdays has not come back any fat, it seems that it was simply accumulated fat...
    Thank you very much to all.
  6. yogi bear
    yogi bear Active Member
    soufend innit
    It is the front cover sweating where the head gasket meets it.
    Very common problem. Unless it’s serious. It’s really not worth stripping the head odd to change the head gasket for.
