*** sr20det subaru impreza classic wagon *£3000* decided to put this up for a bargain and if it doesn't go ill start breaking it after crismass so for quick sale 3K takes it reason being its started to smoke I believe the turbo oil seals have gone ive found a new car so this now needs to go vehicle is located in kent here i have for sale my subaru impreza sr20det, its got 1 years mot on it, its running full stage 1 so roughly just under 300bhp and the same torque, I have just fitted a new sr20det engine to the vehicle with receipt for a bottom end rebuild using acl bearings, reasen being the first engine let go on me new engine has been fitted run and had an oil and filter change both engine and box are sweet any questions please dont hesitate to ask and viewing is welcome will need to be trailored away due to smokeing turbo over seas buyers welcome DRIVETRAIN - t28 turbo - good condition external wastegate inc heat wrapped screemer pipe aluminium radiator inc electric twin fans after market large intercooler all rmd pipe work bent cam sr20det engine after market puk clutch 3 inch exhaust elbow custom 3 inch side exit exhaust sr20det gearbox with quick shift custom one peace prop shaft Horsham stage 1 ecu stich welded engine bay finished in chrome gold after market front and rear strut brace modified s14 front subframe and rack japspeed steering arms and ends driftworks offset rack spacers modified s14 front hubs custom gearbox mount abs deleted custom lower arms custom tention rods braided front brake lines vented front disks with s14 calipers modified Subaru front coilovers and Subaru coilovers rear tubbed front arches EXTERIOR - bonnet pins banded steel 17 inch wheels with 25mm hubcentric spacers wrx side skirts wrx x2 rear spoilers sti front splitter fibre glass arch extentions nismo bonnet vent boot floor has been cut out INTERIOR - aftermarket hydraulic clutch pedal inc resevoir front sound dentening removed after market drivers bucket seat sparco 3 point drivers harness rmd water temp gauge rmd boost pressure gauge after market boss and steering wheel recently fully serviced inc new brake fluid new gearbox oil new pas fluid new clutch fluid new diff oil brand new front tyres also had recent 4 wheel alighnment pm me for more info
Wish i had the monies!! 1500 too much for my budget and id have to sell my crosser to get my budget to start with!
3k is the lowest ill go if not ill break it in the new year I can remove the drivers bucket seat and harness and put it on a standard ecu rather than the stage 1 £2,800
drift subaru impreza 200sx sr20det track car rear wheel drive turbo back on the ebay - auction 99p start
