Some of you already know me...I'm from Road River Club, Portugal. Have been in Oct 2002 Drift Championship with some of you... Here's the situation... I'm almost buying a 200sx S13 in a SR20DET installed. They are doing the job in this precised time... First prob I notice, the Speedo doesn't work...how I resolved that? The Rpm works, because they changed with the S14, but the speedo is the old one (S13). PackMan MC - Road River Club
You need to use the S13 speed sensor, held in the back of the original gearbox by a single 10mm bolt and a 2 pin plug. Stick it in place of the black plastic one in the 'sr20' gearbox. the gears on them are different sizes but they are different lenghts so the gears still mesh. bear in mind that your diff ratio might be different from the manufacturers original, so it may not be 100 per cent accurate but will be close enough. CW OG
