sr20det wierd noise after 2k rpm
Thread in 'Technical Questions' started by alperin-s14, Sep 1, 2012.
  1. alperin-s14
    alperin-s14 Member
    london
    right guys dont get this one mixed up with the vvt rattle because i replaced a brand new vvt sprocket few months back and this one is a similar noise but sounds more like a knocking noise than a rattle it comes between 2k to 4k rpm and its coming from the top on the engine close to the exhaust manifold.. what could it be?
    #1 alperin-s14, Sep 1, 2012
  2. Stavros
    Stavros Active Member
    Isle of bollocks
    Deffo 100% coming from top? Jus a 2-4k knock is usually big ends
  3. alperin-s14
    alperin-s14 Member
    london
    best way to find out? will i be able to check if my local mechanic can take oil sump out and see if any play in the conrod or what ever there called?
  4. Andrex
    Andrex Member
    Southend
    If you can get a video uploaded on to here its normally quite easy to hear if its big end.
    How long have you had the rattle for?
  5. combattuk
    combattuk Member
    hampshire
    iv known blown exhaust manifold gaskets to make strange noises might be worth a look, but the bottom end sounds the best bet
    Sent from my HTC One X using Tapatalk 2
  6. alperin-s14
    alperin-s14 Member
    london
    okay guys thanks for all the info, im in spain atm will be in uk in few days and ill upload a video of it.
  7. alperin-s14
    alperin-s14 Member
    london
    right video posted now guys !
  8. alperin-s14
    alperin-s14 Member
    london
    Where is my friend stavros I need your guidence
  9. alperin-s14
    alperin-s14 Member
    london
    Booked in local mechanics on Tuesday to get the bearings checked out
  10. Paul_88
    Paul_88 Member
    near newcastle
    Mine sounded abit like that when the powersteering pump was dying and 3 people told me it sounded like bottom end, it might not be the powersteering pump but it's easier to sort than the bottom end so probably worth a check
  11. alperin-s14
    alperin-s14 Member
    london
    Did yours sound like when steering aswell? Or just like mine when you accelarate and rev the engine?
  12. Bolf
    Bolf Resident Nut Job.
    PE6
    i'd put money on that being the bottom end bearings.
  13. Paul_88
    Paul_88 Member
    near newcastle
    Both but listening again yours sounds deeper so probably bottom end :(
  14. Ollie
    Ollie LOOSE!
    London
    100% bottom end. stop running it.
  15. alperin-s14
    alperin-s14 Member
    london
    Just keeping the revs low driving short distances to get to work, but ordered the Conrod bearings will change it and see what happens from there
  16. Ollie
    Ollie LOOSE!
    London
    Thats not going to help. You'll need some machine work at least after that, just throwing new bearings in will result in more of the same.
