200SX S14 Rolling Chassis Full cage (EDC/BDC/MSA spec), K-Sport Coil overs and adjustable suspension arms all-round, big brakes front, braided brake hoses all round, stripped interior, Walbro pump. ~80k miles, auto diff, Whiteline ARBs front & back, aluminium subframe locks. P reg Marlin Blue. OS door is dented but have a replacement pair of glassfibre doors. OS wing replaced, needs painting to match colour. Suspension recently aligned. Litterally a case of dropping the drive train and engine loom in and driving it. Selleded! £1500 Mazworx Z32 Gearbox c/w Gearbox, adaptors, brackets, Shifter and ally prop for S14, bought as part of the orignal SXOC group buy - never used on the road or track. Proven to take lots of power and abuse. SOLD! £950 SR20DE on throttle bodies High compression (1.5mm head skim) gasflowed head, Adjustable Cam sprockets, Dual valve springs, ARP head studs, Dynoed at APT 159bhp, Perfect for a kit car or engine conversion. (Fidanza flywheel and ACT clutch fully mapped ECU also available) {} £750 * Fidanza flywheel&Clutch £150 * Mapped VEMS ECU inc loom and wideband £550 SR20DET VVT Bottom end Eagle Rods, Wiseco pistons, Aero profiled crank, Professionally built see: :: AngelWorks Technologies :: Still in its protective bag. SOLD! £700 Garrett GT30R brand new never used. Dual ball bearing. Compressor: 76.2 mm, 56 Trim, 0.60A/R. Turbine: 0.82A/R T3 style. External Wastegate. SOLDED! £750 Full Race SR20DET Top mount manifold T3 flange, downpipe, screamer pipe and Tial wastegate, brand new never used. SOLDENATED! £1000 SARD 850cc injectors, brand new never used. SOLD! £250 Ogura Racing Clutch (ORC)"D1 Spec", Twin plate, good condition. Soldenated! £300
Sim, The VEMS has a map sensor but its only used for barometric correction as the system has been setup to run AlphaN because of the throttle bodies.
What could be better on a rainy day than to plan next years project - probably using the stuff for sale here
I'm really only looking to shift the car in one whole peice - I dont have the time to work on the thing to get it finished so I wont be able to find time to break it in all honesty.
That fullrace fanny mold is the sex didnt even know they done one for the sr! i knew bout the evo stuff! Is it T3/T4 flanged? And is it for s14 or s13? need to have no ABS id assume? Not that iv got the moeny just intresting
No project, well not a car one anyway, a start-up here in Cambridge is going to be occupying my time.
