standard R33 gtst over boosting
Thread in 'Technical Questions' started by philip_200, Oct 16, 2017.
  1. philip_200
    philip_200 New Member
    as above pretty much standard car, has FMIC but standard turbo,actuator and boost solenoid but once you give it throttle it will overboost and hit fuel cut ive seen it hit 15psi by the time i had let off?
    have changed the actuator still no difference
    also while the actuator was off i checked to make sure the waste gate was opening freely and not seized so theres no reason why the actuator shouldn't be able to open it?
    car is a 1996 spec 1.5 gtst
  2. BenRice
    BenRice Well-Known Member
    No leaks in the vacuum line to the actuator?
  3. philip_200
    have replaced all the vacuum lines with brand new pipe but will double check in the morning
    r33.
  4. dandadude
    dandadude Active Member
    Double check you haven't accidentally got your vac lines the wrong way around, sounds like you don't have a decent feed to your wastegate any more, either incorrect line or T-piece for boost gauge poss fitted incorrectly, some T-pieces have an orifice and if it's towards the wastegate and not the gauge it's like the wastegate pipe is disconnected!
  5. dandadude
    Also try running it without the solenoid so running the line directly from the boost take off to the actuator, it should then just boost to actuator pressure.
  6. philip_200
    so the vac line from intercooler pipe straight to actuator?
  7. dandadude
    Yep do that and see what happens, should run at actuator pressure which I can't remember off hand but sure it's less than 15psi on a stock r33
    EDIT - If this makes a difference then re-fit the T-piece and try again.
  8. philip_200
    will i need to block of the other pipe that goes to the t or just leave it , stock car should be 8 or 9 psi i think
  9. BenRice
    Yup stock shouldn't be anymore than 9psi.
    Just run a vacuum line from the intercooler pipe to the actuator.
    Block the line going to the recirc valve, I believe that's where your T is going?
  10. philip_200
    yea thats were t is gong heading down to the yard now so will try this out and see how it goes
  11. philip_200
    So that worked stayed around 6 psi mark , what does that mean?
  12. BenRice
    Ok, now hook up the solenoid, but keep the line to the recirc valve blocked and see if it does it
    If it overboosts, factory boost solenoid is bung
    If it doesn't, there was a leak in the recirc line
  13. dandadude
    Glad that's worked you should be able to work it out doing what BenRice has said which is what I was trying to say in the first place lol.
