steering knuckle, lock proplems
Thread in 'Technical Questions' started by carlrst, Sep 2, 2010.
  1. carlrst
    carlrst Member
    norfolk
    hey, just finished installiing some modded knuckles. on one side i have pretty good lock, and the other has weaker than standard, was told theres nothing else needed with these, but am i missing something??
    and the other side...
    Uploaded with ImageShack.us
  2. al.
    al. actually dom joly
    Worthing, near Brighton
    looks like the length of your tie rods isn't balanced either side. what's the steering hitting to stop it coming out further?
  3. carlrst
    carlrst Member
    norfolk
    it only stops because the other wheel is on full lock. hmmmmm
  4. Polo
    Polo Sr20 parts man!
    S-body Automotive.com
    Who done the knuckles?
    Is the rack defo centred? and do both wheels defo point forwords when rack centred?
  5. al.
    if the wheels both point straight ahead when the steering wheel is straight then that's some extreeeeme ackerman. have you got a pic of the knuckles/tie rods/rack installed?
  6. carlrst
    carlrst Member
    norfolk
    just checked, and they wont both point ahead? rack?? was made by some one on here
  7. al.
    errr...set the toe and tracking correctly....
  8. carlrst
    carlrst Member
    norfolk
    will give it a go. is it normal for the tracking to be totaly out like that!?
  9. jdmash
    jdmash Active Member
    Wolvohampton
    Ah if you don't know that you shouldn't be fitting them :s
  10. S13-ste
    S13-ste Member
    Dubland
    you have just changed how things line up, of course tracking need to be sorted after it:smash:
  11. bigrichy
    bigrichy Team Beard
    Northern Ireland
    Gonna be a hoot driving that to get the tracking done!
  12. carlrst
    carlrst Member
    norfolk
    Hey u learn by doing rite. Yea should b fun lol get it done by eye first :)
  13. bigrichy
    bigrichy Team Beard
    Northern Ireland
    Absolutely, rare enough someone will give good guidance without ripping your face off with a keyboard, so might as well get stuck in :thumbs:
  14. superclarkey
    superclarkey DORITECH MOTORSPORT
    West Midlands, Halesowen.
    if you've just put them on and not changed the track, then they will be MASSIVELY toed out, set them so they are close to zero toe as posible.
    Clarkey.
  15. SteveC200
    SteveC200 Used to drift, now I don't.
    Essex
    But centre the rack first.
  16. carlrst
    carlrst Member
    norfolk
    just cetred it as best as i could, but the ends are maxed out nearly, may need longer rods?
  17. superclarkey
    yeah need to extend the rods.
  18. carlrst
    carlrst Member
    norfolk
    would tien rods to it, or is it a diy job
  19. S13-ste
    S13-ste Member
    Dubland
    Tien tie rods are longer but for even more lenght give polo a shout about the extentions he sells. then you just cut your and weld the entention in
  20. carlrst
    carlrst Member
    norfolk
    ok cheers will do that :)
