steering knuckle, lock proplems
Thread in 'Technical Questions' started by carlrst, Sep 2, 2010.
  1. FireStorm999
    FireStorm999 Active Member
    or just buy the DW rack spacers
    i have the opposite problem to you.
    running standard knuckles and DW spacers.
    both my wheels toe in - i need to cut my rods down or use z32 ones.
  2. g6mmc
    g6mmc Member
    northern ireland
    or possibly try ends from an astra, cant remember what year tho
  3. carlrst
    carlrst Member
    norfolk
    ok just got it tracked and made mods for clearance with a tappy stick:wack:
    took the lockstops rite off, need to make some up, but it dosnt seem to go over centre. wich is awsome. anyway heres the result
    better than it was so, not quite hero spec or anything.
    Uploaded with ImageShack.us
  4. S13-ste
    S13-ste Member
    Dubland
    and whats the trailing wheel like?
  5. superclarkey
    superclarkey DORITECH MOTORSPORT
    West Midlands, Halesowen.
    You need to put it on the floor to see actually how much lock you've got, it will go over centre when drifting :)
  6. carlrst
    carlrst Member
    norfolk
    trailing wheel, will test it out properly tomoro, (private land:thumbs:)
  7. superclarkey
    Thats not good mate, i would cut them and try again :)
  8. carlrst
    carlrst Member
    norfolk
    aw realy ?? not enough that side? :(
  9. superclarkey
    I tell you right now, the only reason you've got so much lock is because the trailing wheel isn't going anywere, it will work, and you may like it.. but at low speeds it will spin you round.
    It will turn in amazing tho haha.
  10. carlrst
    carlrst Member
    norfolk
    Aw man this sucks, how can I sort it. Got pod on the 15th. Back to standard??
  11. FireStorm999
    before changing it, have you tested it?
    what works for clarkly might not work for you and visa versa.
    too me i think your wheels look spot on, both heading same direction etc.
    but i dont quite understand how changing the hubs works so.....go figure.
    but test it before you chuck it.
  12. superclarkey
    Add shit loads of camber and it will be mint :-)
  13. carlrst
    carlrst Member
    norfolk
    Yea goin to test it. And yea was thinking s14 lower arms
