Stretching NS2-R or federal 595rs 235/40/17 Onto a 10J????
Thread in 'Technical Questions' started by Ross009, Nov 20, 2015.
  1. Ross009
    Ross009 New Member
    Hi All,
    Having bit of trouble deciding on tyre size would a 235/40/17 go onto a 17"10J rim I dont want loads of stretch, or would a 255/40 17 be a better option? Do they road slick type tyres tend to run wide?
    Thanks
  2. sparky_s13
    sparky_s13 Active Member
    South Wales
    Ive run 245/40 on a 9.75j wasnt loads of stretch IMO
    I will see if I can find a pic
  3. Ross009
    Ross009 New Member
    Thanks theres a look I want to achieve similar to the pic below but its hard to get across what I want to achieve as its a lot of money to spend and get it wrong, I want it to look as close to that tyre fit maybe a tiny amount of stretch
  4. sparky_s13
    South Wales
    245 on front, 225/45 on rear
    All tyres differ slightly though and I have heard the federals are slightly different to what they say the should be so 235 might be a bit much.
  5. Ross009
    Ross009 New Member
    ok cheers for your help!
  6. lewyS14a
    lewyS14a Active Member
    Normal Federals and Nankangs stretch really well but the tyres you have selected are the more track focused versions wich will have a stiffer sidewall wich is not very good at all.
  7. Ross009
    Ross009 New Member
    but a 255/40/17 federal 595-rs wouldnt be too stretched would it?
  8. chodjinn
    chodjinn Active Member
    Hardly at all on a 10j. I have 265 and 285 rsr for some 10js, no stretch at all.
  9. Ross009
    Ross009 New Member
    similar fit to the pic i posted above?
  10. chodjinn
    not far off with the 285s. But then again 10j is a big wheel and 285 is a big ass tyre
  11. Starkey
    Starkey Administrator
    Staff Member
    Birmingham
    Check out Tyrestretch.com
    lots of photos on there with various widths mounted on a 10J rim
  12. Jites
    Jites Active Member
    Aberdeen
    I run 215/40/17 on a 9.5j no issues, RSR's too, went on no bother. there is little to no stretch on the OP choice
  13. JasonER34
    JasonER34 Member
    RSR's do have a stuff side wall, be effort to fit over normal road tyres, but once they're on they'll be great and tidy bit of stretch won't be the end of the world (if it is just a tiny bit) but well fitting straight side walls would look better and more like the photo you like as above
  14. H05TYL
    H05TYL Member
    Land of the long white cloud
    A 265 or 275 on a 10" rim will be closest to the look of the tyre you posted.
  15. diamondsink
    diamondsink Kyouto Drift
    Kyouto HQ, Bristol
    Im running a 225/40/18 RSR on a 9.5j, its less stretch than a normal tyre as they are slighty squarer on the profile.
  16. Ross009
    Ross009 New Member
    do you have a picture mate?
  17. Ross009
    Ross009 New Member
    Thats what I thought, and I don't mind , I think I'm trying to achieve the impossible fitting a 10j with a road style slick like the pic I posted but getting it on standard arches may have to just fit them then see what it sits like, its on a spec 1 R33 GTST, also I don't have the car yet as its still on the boat.....
  18. Stevo309
    Stevo309 New Member
    One problem is that i have not found all tyres to be equal in width. I ran 235/40/17 maxxis maz1 on a 10j rim and they only had a small amount of stretch fitted very well and looked good. Now i have Nankang NS2 (not r) in 235/40/17 and they are noticeably narrower than the maxxis, in fact on the 10j rim there is loads of stretch. Going back to the OP, if Nankang are all the same width they may not be wide enough.
