GC8 Impreza Terzo ltd no.115 1997 S555 BLU licence plate Been garaged since 2017 61k miles Unopened original ej20k ran on Millers and vpower ESL ecu with motor sport pack Parallel fuel rails id1000 injectors Braided PTFE an-10 lines Fuelab fpr Sytec 380lph external pump Litchfield swirlpot Walbro 255lph tank pump Battery relocation Front mount intercooler HKS bov Shaved intake manifold vac ports blocked 12mm thermal spacers NKG iridium plugs Bosch 8mm leads Uprated ignition coil RCM time attack catch tank Syms manifold Black Label pedestal Turbosmart Compgate 40mm Holset hy35 10cm t3 single scroll Blitz Nur Spec exhaust RCM low temp thermostat Custom rad with cap welded on Expansion tank delete Simplified coolant routes Toyo R888 255 40 18 JR10 10j low et wrx 4 pot front callipers sti Brembo rear callipers Brake booster delete Forester master cylinder Meister R zeta r coilovers 10kg front 8kg rear H&R springs Type RA-R power steering pump remove power steering reservoir v6 sti spoiler Vortex generator sti rear lights Visual Autowerks rear window vents AWB arches Cut and welded rear quarters Type RA bonnet v8 sti scoop 22b rep vents Custom grill Glass headlights with black insets 22b rep front bumper P1 rep lip Sti v7 interior Splash Sports boss kit OMP dished wheel Greddy Profec Oled boost controller Needs the Proline brake line kit, Tilton bias valve and hydro installed which is included. Needs downpipe fabricated. Needs a map, it does start and move. I was planning a 6 speed swap, I have a donor Legacy 3.0r Spec B for this job. ORC twin plate clutch, Compbrake 6 pot front and 4 pot rear kit including the floating disks and Hawk pads. Also planned to do a 2.1ltr closed deck block build i have 2 ej20g closed deck blocks v6 sti big port heads Complete v4 sti engine for the heads 2 sets of RCM Omega pistons RMC Arrow rods ARC sump Oil Cooler Beatrush undertray I have been distracted from this car by a 180sx, so thought i'll see if there's any interest in this project. Ideally this is for someone who knows Subarus well. Looking for around £7000 for the lot or possibly a px {} {} {} {} {} {} {} {} {} {}
