For Sale Supra JZA80 parts - Engine/Drivetrain/Interior/Exterior
Thread in 'Parts for sale' started by parm_93, Feb 20, 2019.
  1. parm_93
    parm_93 Member
    Hi all,
    Loads of Supra parts for sale, mostly removed from a UK spec TT6 with mileage at 41260 miles.
    Engine/Engine parts:
    Upper timing belt cover (2 available) - £10
    Lower timing cover - £30
    Viscous fan TT - £60
    Thermostat - £10
    Lower water neck - £20
    Starter motor - £60
    UK 550cc injectors with fuel rail - £150
    UK injector resistor pack - £60
    Throttle valve motor P/N 89632-14010 - £20
    Throttle position sensor P/N 89452-33010 (TRAC) - £50
    Timing belt tensioner and bracket (good bearing) (2 available) - £30
    Timing belt hydralic tensioner - £10
    Crank and cam pulley bolts - £10
    Knock sensors x 2 - £50
    Oil pressure switch - £20
    Lambda Sensor - £30
    Stock cam gears - £10
    NA fuel rail in VHT black - £20
    NA throttle cable - £10
    NA Ignition coil - £20
    NA Ignition coil to distributor lead - £5
    Drivetrain/chassis:
    Big case driveshafts - £300
    Steering rack - £150
    Brakes:
    Front and rear stock UK brake pads - £40
    Stock brake lines for ABS (J-Spec) - £10
    NA ABS/Trac relays - £10
    Exterior:
    UK/EU spec rear lights with looms - £200
    Scuttle panel rubber seal (one hole torn) - £10
    Space saver wheel - £40
    Washer bottle and motor (J-Spec) - £40
    Interior:
    Celica GT4 ST202 steering wheel with airbag (airbag faded condition) - £20
    Passenger A pillar trim - £25
    Accelerator Pedal - £20
    Handbrake (gaiter is not OEM) - £20
    Glovebox (lower) - £30
    Door sill trims both sides - £30
    Stereo din blanking cover - £5
    Fuel pump/tank cover - £5
    Rear-view mirror - £10
    Passenger side quarter panel plastic trim - £20
    Driver side corner boot plastic - £30
    Interior blower plastic corner pipe - £5
    Switches:
    Dimmer switch - £15
    ECUs:
    UK fuel control ECU P/N 89570-14230 - £60
    20190210_155838280_iOS.
    20190218_143530626_iOS.
    20190218_162331635_iOS.
    20190223_150550197_iOS.
    20190303_163128903_iOS.
    20190217_122339647_iOS.
    20190218_160554726_iOS.
    20190228_175206503_iOS.
    20190218_155802191_iOS.
    20190217_174718375_iOS.
    20190210_171729760_iOS.
    20190210_172722192_iOS.
    20190218_154211556_iOS (1) (1).
    20190218_163058645_iOS.
    20190217_173209927_iOS.
    20190210_164055441_iOS.
    20190210_164041609_iOS.
    #1 parm_93, Feb 20, 2019
  2. parm_93
    parm_93 Member
    Bump. Post updated and priced reduced.
  3. parm_93
    parm_93 Member
    bump post updated
  4. parm_93
    parm_93 Member
  5. parm_93
    parm_93 Member
  6. tengu
    tengu Member
    Rolling shell by any chance mate ?
  7. parm_93
    parm_93 Member
    Sold mate
  8. parm_93
    parm_93 Member
  9. Tom Khor
    Tom Khor New Member
    Is tailight available?
