Swapping 2jzge vvti into 2008 e92 320i
Thread in 'Drifting Chat / Pictures / Videos' started by Khayam Khurshid, May 26, 2021.
  1. Khayam Khurshid
    Khayam Khurshid New Member
    Ireland
    Hi lads i really need yer help as its my first project and am aiming around 850 to 900whp.
    I bought the lexus gs300 1999 for the engine ecu and wiring.
    And i have 320i coupe e92.
    I want to forge the engine as my friend told me to get all this stuff
    Connecting rods
    Prime crower rods
    Kings race bearing set
    Main bearing
    Thrust washer ,rod bearings
    Arp 625 2jz head studs
    Brain crower valve spring retainer kit
    (Behives kit)
    Gsc valve stamp seal kit 16
    2jz oem oil pump
    Toyota 2jz timing belt tensioner
    Lexus oem gasket set for 2jzge
    Toyota 2jzgte head gasket
    Cam shafts calford
    Injectors
    Fuel pump system
    Fuel riley
    2jz Ignition system kit
    330d transmission and differential
    I am wondering what else i would require to build my project?
    Can anyone please help me!!
    #1 Khayam Khurshid, May 26, 2021
  2. Japtorque
    Japtorque Active Member
    KENT
    GE has no oil squirters but can be installed
    GE and GTE have different oil pumps,
