Swapping a 2JZ into my 240 Volvo NA-T
Thread in 'Project Cars and Builds Threads' started by 2JvLo, Sep 30, 2016.
  1. Scoobystu
    Scoobystu tag-less
    Northampton
    looking good Bro!!!
  2. 2JvLo
    2JvLo Member
    Netherlands
    Made some progress one the inlet manifold. The original lower manifold has been machined flat. When that was done i was able to measure the exact location of the runners.
    Made a 3D drawing for a plate that will be welded on the runners and in the planum. Next day got myself a plate of alluminum and started machining.
    Plate done, and fits perfect!
    Now the plenum needs to be machined and then everything can be welded together.
  3. counteract
    counteract -o=me
    This awesome!
    Out of curiosity, what clutch setup are you intending to use? Have you implemented a PMC flywheel spacer/adapter?
  4. 2JvLo
    2JvLo Member
    Netherlands
    Tanks!
    The car is going to be daily driven therefore i bought an original BMW clutch. It's supposed to take 600nm of torque, so we'll see how it holds. The PMC flywheel is fitted directly to the flexplate.
  5. Markfpc
    Markfpc Member
    Burton, staffs
    Nice build, have you got much experience with the dta ecu?? I can't PM you for some reason
  6. 2JvLo
    2JvLo Member
    Netherlands
    Thanks, yeah i've already send driftworks mails abbout that but they wont reply anymore, my email is in the profile. This could use some update's, will be working on
    I know my way round dta.
    #26 2JvLo, Oct 31, 2016
  7. Markfpc
    Markfpc Member
    Burton, staffs
    I can't find your email I have a map for a 1jz vvti if that's any use?
    #27 Markfpc, Oct 31, 2016
  8. 2JvLo
    2JvLo Member
    Netherlands
    Have been buissy with some other shit lately, but made some small progress:
    catch can mount made, This is one of those ebay things (god i love ebay). It has been modified to fit a breath to atmosphere filter, filled with stainless steel wool, pipes with holes and a crane on the bottom.
    Also the previous owner of the car did some weight reduction with 5mm holes i guess.. Looked awful so welded those.
    A local company had some of those alloy radiators in stock. This one seems to fit best, for a Toyota corolla. Unfortunately the dimmensions they gave were +- 10 cm i guess... have to make that fit later. :smash:
    did some more work on the tunnel but forgot to take pictures
  9. Scoobystu
    Scoobystu tag-less
    Northampton
    looking good !!
  10. Olliehood
    Olliehood Member
    How much did the pmc kit cost you ? Car looks cool I have a 940 with tuned redblock
    Where abouts in the Netherlands do you stay in sometimes go to tilburg
  11. Derrick King
    Derrick King New Member
    Arlington tx
    Hey could I get your drawing and measurements for this plate
  12. 2JvLo
    2JvLo Member
    Netherlands
    Nice to see other people like it! Only one thing.. The bottom gearbox bolt is off. Send me an email for it.
    The PMC kit is on ebay.. Don't know what the current price is. Tilburg is a bit far from here .. does Texel say anything to you?
    Currenty The project is a bit on a stop. Bought a 71'' cadillac that needs a little attention as daily.
  13. Derrick King
    Arlington tx
    Thanks for the reply man!!! But Yea I am also going to do the 2jz ge swap, to a beautiful cream colored 81 Volvo 240 i have already removed the engine and trans , and I was wondering if its not too much of your time if you could send me everything that I need and the measurements of everything that was custom fab
    derrickoking94@gmail.com
  14. Derrick King
    Arlington tx
    IMG_20170222_180154.
  15. Tim97
    Tim97 New Member
    Netherlands
    Leuk om te zien dat dit iemand in Nederland doet, hoe ga je het doen met de rdw etc. Ben het waarschijnlijk zelf ook van plan alleen dan met een gte blok. Ben benieuwd naar het eindresultaat
  16. e461jzvvti
    e461jzvvti New Member
    ksa
    nice job 2JvLo really liked your job
    and brilliant idea to machine the plate so you can use GS6-53DZ
    in my e46 318ci 1jzvvti drift build i am using the same adapter+ flywheel from pmc and e46 330ci clutch
    but fortunately i run bmw e46 318ci RMFD-5 speed gearbox cuz
    in middle east we do not have bmw diesel models so i have to import the GS6-53DZ still cheaper than r154 !!!!!
    i was thinking to lengthening transmission input shaft but i think i will do same as you i will just machine the adapter plate
    and sorry for my bad English
  17. Swampy442
    Swampy442 Active Member
    Lincoln
    Love this build thread :)
  18. rx7ali
    rx7ali Member
    Milton Keynes
    Nice work! Wish i had access to a CNC machine and mill to make bits for my swap :p
  19. BenRice
    BenRice Well-Known Member
    New Zealand
    Absolutely! Maybe start a separate build thread if you don't mind?
  20. narancs
    narancs Member
    Hungary
    The T5 swap looked clean!
    I have a 945 which had a T5 but the swap didn't look as nice as yours :) Picture
    Now I'm doing a Swedish 2jz... T6 with a HX40.
