Brand new, unfitted T3/T04e turbo & accessories Specs: T3 .63 turbine housing, common ford 5 bolt flange and 5 bolt to 3" V band adapter - turbine inlet has been slightly ported/gasket matched. T3 "stage 3" turbine wheel. Oil cooled centre section fitted with -4an oil feed flange and -10an oil return T04e compressor housing, 57 trim compressor wheel (56.5mm inducer, 76mm exducer - pretty much identical size to a GT3076) Comes with a -4an braided oil feed line and a couple of -10 drain lines - one with a 90 degree AN hose end and the other with a 45 degree AN hose end Selling due to a change of plans (namely buying a TD06) this will be ideal for a 2-2.5l engine and is good for 300-450bhp. located in Gateshead, Postage available - Price £150
