Don't worry bout it just needs a clean and paint the subframes not to bad its just the brake discs with sitting doing nothing are a bit rusty Its more the fact ive striped and painted the underneath and not painted the subframe. can't wait to fit all my new suspencion arms
no more cutting. this was a little scary happy with the results thow Its all prep work now getting ready for prime and paint
Chassie primed i will be deleting the fuel cap filler hole in the over fender and fitting them next as well as rubbing down all the panels and priming them.
So getting rid of the fuel filler hole in the over fender Fitted ali plates on the outside of thefender fiber glassed the back After its all dry took of the plates And after some sanding and shaping. Not perfect but i think it will look ok once it is painted Fitted the oposit side And offcourse had to try a wheel on Needs a spacer!!!!! What else did i get upto today? Removing the door internals realy does shed some weight Can only hope removing all this metal makes up for fitting the cage. Weight wise.
Got the other over fender fitted Looks okwe wll see what it looks like in primer After preping the doors for paint i decided to try the front end on to see if it all fits Sorry to anyone who hoped for a s14 front end ive always wanted to do the 14.5 conversion with the vertex kit (sorry adam) Any way im glad i tryed everything up as i can see i need modification to the chassie to allow room for the head lights. Top tip for anyone trile fit everything as nothing on a build like this is a bolt on modifiaction I'm going to order up tube for making the intercooler support and bumper support. will also have to order my bonnet.
Mehhhhhh... Joking With the amount of work you've put in, I'm not gonna knock the front. Will comment when she's painted and ready
Sorry not to much to report as progress. Ive been doing some body work and fiberglassing i'm getting there slowly. If i can get the chassie done and the front bumper support made get it away to paint i can consentrate on the engine rebuild. Good luck to all the guys starting the first round of the BDC in a few weeks
thanks Chassie is away at the painters Striped the subframe and stearing rack ready for modification clean and paint Got my GTR back end again needs a clean and paint S14A diff with ports for oil cooler GTR diff Comparison Photos
Had to get the good camera for these shots love midnight purple I will keep the updates coming in the next week hope to get the suspencion on it this weekend!!! Big thanks to norman at norlan auto bodys
is this paint expensive? trying to figure out what colour to eventually paint mine and this is gorgeous
Took 4 ltrs of paint nissan paint code LP2 the paints not expensive but it depends on who you get it from. Not sure my self as my painter tokk care of it for me
