The HOLSET Thread
Thread in 'Technical Questions' started by dale_b, Nov 23, 2012.
  1. carlg
    carlg New Member
    I thought i would update you guys on my mk2 golf, i used to run a hx35 with a 14cm hotside on an open manifold, I have since changed to a hy35 (10cm hotside) which reduced the spool about 500 or so rpm and i am now running E85 last weekend i was racing at santapod and managed to run a 10.63 @ 133mph with a 40 shot of nitrous. The terminal speed was the same as the hx35 with a 100 shot on petrol with the hy35 on e85 and a 40 shot so its making roughly the same power with a much smaller shot of nitrous.
    • Like Like x 3
  2. carlg
    carlg New Member
    So I took it to doorslamers and went faster on a 75 shot now 10.44 @135 mph...
  3. bigdave z20
    bigdave z20 Member
    Great results from the HY35 dude
  4. Goddaz
    Goddaz Member
    whats a sensible holset for a 13b. standard ports? hx40?
  5. smokebillowing
    smokebillowing Active Member
    Can anyone identify this holset? Is this 12cm or 14?
    IMG-20180604-WA0019. IMG-20180604-WA0014. IMG-20180604-WA0017. IMG-20180604-WA0018.
  6. bigdave z20
    bigdave z20 Member
    It should have a number inside the t3 twinscroll flange.
  7. McFarlo
    McFarlo Member
    Ooohhh, HX35G, fancy watercooled-ness.
    As dave said, there should be a number inside one of the scrolls on the twinscroll flange of the turbine housing. Looks to me like a 12cm, could be mistaken though.
  8. smokebillowing
    It is a 12cm... thanks dudes
  9. ruby1j
    ruby1j Member
    What intercooler piping size are ppl running? I see 4" downpipe is the way to go for turbo response..wondering the pros and cons of running same size outlet intercooler piping vs 3" intercooler piping. I made 506whp on 3" piping, however, response wasnt super great. I would like to reduce to same outlet size from turbo...just concerned i might lose power.
  10. McFarlo
    McFarlo Member
    Stolen this from DSMTuners, not sure how much of it is 100% accurate but the maths seems okay?
    Start copypasta
    *.4 Mach is the point at which air becomes turbulent and losses in efficiency start to occur exponentially. The key is to stay under that speed. You want to use the smallest piping possible that still flows enough to meet your needs. Larger than necessary piping increases lag time with no measurable gain
    The velocities are in miles per hour and mach, and the flow rates are in cfm. Measurements for the piping are in inches.
    2" piping
    1.57 x 2 = 3.14 sq in
    300 cfm = 156 mph = 0.20 mach
    400 cfm = 208 mph = 0.27 mach
    500 cfm = 261 mph = 0.34 mach
    585 cfm max = 304 mph = 0.40 mach
    2.25" piping
    3.9740625 sq in = 1.98703125 x 2
    300 cfm = 123 mph = 0.16 mach
    400 cfm = 164 mph = 0.21 mach
    500 cfm = 205 mph = 0.26 mach
    600 cfm = 247 mph = 0.32 mach
    700 cfm = 288 mph = 0.37 mach
    740 cfm max = 304 mph = 0.40 mach
    2.5" piping
    4.90625 sq in = 2.453125 x 2
    300 cfm = 100 mph = 0.13 mach
    400 cfm = 133 mph = 0.17 mach
    500 cfm = 166 mph = 0.21 mach
    600 cfm = 200 mph = 0.26 mach
    700 cfm = 233 mph = 0.30 mach
    800 cfm = 266 mph = 0.34 mach
    900 cfm = 300 mph = 0.39 mach
    913 cfm max = 304 mph = 0.40 mach
    2.75" piping
    5.9365625 sq in = 2.96828125 x 2
    300 cfm = 82 mph = 0.10 mach
    400 cfm = 110 mph = 0.14 mach
    500 cfm = 137 mph = 0.17 mach
    600 cfm = 165 mph = 0.21 mach
    700 cfm = 192 mph = 0.25 mach
    800 cfm = 220 mph = 0.28 mach
    900 cfm = 248 mph = 0.32 mach
    1000 cfm = 275 mph = 0.36 mach
    1100 cfm max = 303 mph = 0.40 mach
    3.0" piping
    7.065 sq in = 3.5325 x 2
    300 cfm = 69 mph = 0.09 mach
    400 cfm = 92 mph = 0.12 mach
    500 cfm = 115 mph = 0.15 mach
    600 cfm = 138 mph = 0.18 mach
    700 cfm = 162 mph = 0.21 mach
    800 cfm = 185 mph = 0.24 mach
    900 cfm = 208 mph = 0.27 mach
    1000 cfm = 231 mph = 0.30 mach
    1100 cfm = 254 cfm = 0.33 mach
    1200 cfm = 277 mph = 0.36 mach
    1300 cfm max= 301 mph = 0.39 mach
    In order to convert from Lb/Min to CFM for the equation above, you take the flow rate in Lb/Min for your turbo (generally an educated guess based on the pressure ratio and power created) and multiply it by 14.27. That will yield the CFM flow for your setup.
    For Example:
    T3/T04e 57trim .63ar @ 21psi makes 452 whp
    This turbo is known to have a 50lb/min compressor wheel which will make ~500bhp. Since we're using whp above, we can assume this turbo is pretty close to its max of 50lb/min.
    Now to convert that to CFM, you take 50lb/min x 14.27 = 713.5 CFM. When you refer to the table above, you can see that we're starting to max 2.25" piping, but we're still in the "good" range for 2.5"
    but it also depends on how smooth the piping is inside... and all the bends. this i would say is " perfect piping conditions" and if you would pick a number to upsize your piping at it would be when you hit about the .3 maximum .35 mach region.
    End copypasta
    Personally, I wouldn't have thought there was a monumental amount of response to be gained from stepping down intercooler pipe sizes. It does look to improve the air's velocity by a decent amount, but whether that would in turn equal a noticeable "response" change is something I wouldn't know enough about to comment on. I haven't seen any testing done on this either, just maths and theories.
    Perhaps Stav could comment or share knowledge on the matter, as I'm sure he would be better equipped to inform you than I would.
  11. fennyLET
    fennyLET Member
    Hey guys. Holset hx32w with 12cm twin scroll housing. How does that compare to the likes of a hx35 or hy35 on a 1jz? Just curious.
    796C0FE0-82CE-4DEB-B664-14870858F6B8.
  12. BenRice
    BenRice Well-Known Member
    Pretty good option tbh. If you've got a twin scroll manifold then it's ideal, but even if not it'd still work really well.
    Some may say slightly undersized, but the 12cm turbine housing will flow well up top.
    Anymore photos? Are you going to keep it internally gated?
  13. fennyLET
    fennyLET Member
    No I’m going to run it externally gated.
    5E0BCC12-B6FA-402D-AFFC-C6A0B0F0B923.
  14. bigdave z20
    bigdave z20 Member
    Will work well dude, as Ben said a twinscroll manifold would help spool but cheapest option for better response is a 3.5 or 4" downpipe.
    It's pretty much in between a HY35 and HX35
  15. fennyLET
    fennyLET Member
    Ok cool. I don’t think I have room for any more than a 3” downpipe and I’m on a japspeed 1jz vvti manifold with a eBay 44mm gate. I think I’m going to keep it on the shelf until I can afford standalone. Currently I’m on emanage blue but I can’t really find anyone to map it on my current setup.
  16. BenRice
    What boost level is the current setup running? And what turbo?
  17. Benkid
    Benkid Member
    Update. Had the car setup and the results aren't great. Certainly not what I was expecting. Any ideas on why it could be so laggy?
  18. thebe
    thebe Member
    Did you talk to the tuner? What did he/she say?
  19. Benkid
    Benkid Member
    They said that it's not a great turbo choice.
  20. BenRice
    Did you end up seeing if the VCT was activating?
