The Lexus Build ......
Thread in 'Project Cars and Builds Threads' started by DriftLexus, Oct 17, 2005.
  1. DriftLexus
    DriftLexus BDC Scrutineer
    Back in the UK...!!
    The Lexus Re-build, phase 3 "Taking it serious"
    As i soon will be embarking on a major re-build of the lexus, i thought i would start the topic so that a couple of the other guys involved, or hopefully will be involved can contribute there thoughts and ideas as it progresses
    Here are Phase 1 and 2 of the original builds...CLICK HERE
    The original build was a track car,and endurance racer, was used mostly in Germany the second re-build was the colour change and minor changes made to turn it into a drifty car
    the 3rd build, will be a complete stripdown and re-build, the engine is being changed to a turbocharged 3S_GE from an altezza., it currently uses a tweeked Toyota motorsport N/A 1G-FE
    a full weld in cage will replace the facory 6 point TRD cage, this will allow me to ditch the suspension turret braces and floor-chassis braces
    the fuel system is being replaced with a fuel cell, i can ditch the non fuel teturn line system and 70litre tank then!!
    hopefully stand alone ecu...or at least minimum use of the factory multiplex system, which is truely a pain in the ass to work with
    ive yet to decide on what forced induction parts to use...
    but the internals will more than likely be TODA low compression pistons and steel crank, Eagle H rods will connect them
    as for the head, no definative direction has yet been decided, but the varible valve timing will be disabled
    sat on the living room floor at the moment are some of the parts that have arrived from japan.
    KAAZ 2 way LSD
    TRUST high volume oil pan
    BORIS Factory 5.12 rinal drive gear and pinion
    TRD Engine mounts/gearbox mounts
    ORC ultralight flywheel and clutch
    HKS oil cooler
    El Sport differential mounts
    DTEC suspension bushes
    sat in the garden is the engine, gearbox.............. :wack:
    #1 DriftLexus, Oct 17, 2005
  2. starlet_V8
    starlet_V8 Member
    London
    good luck with the rebuild :thumbs:
  3. Butuz
    Butuz Member
    Cardiff, UK
    Sounds ambitious mate keep us informed - and plenty of piccs right!
    Butuz
  4. DriftLexus
    Back in the UK...!!
    thanks.
    not so ambitious...just getting the logistics sorted so each part of the re-build happens at the right time
    pics wont be a problem
  5. oli
    oli -nightspirit-
    oz
    I didn't see the 3sge engine and box when i was there Matt??? hidden in your shed?
    get some pics of the bits on the floor :nod:
  6. DriftLexus
    Back in the UK...!!
    tis in the garden mate..............hidden, under a bike, kiddies slide, and part of a bar-b-q
  7. mykkk
    mykkk Member
    London, UK
    good stuff, I've always had a thing for the lexus
  8. sideways.taff
    sideways.taff - www.tafftune.com -
    Göteborg
    You aint seen ambitious yet! :no:
    Drifty Lexus project sounds interesting though :nod:
  9. CorollaRWD
    CorollaRWD -RUTHLESS-
    Is that Russian spec, lol
    When we going to see the monstor out? :worthy:
  10. DriftLexus
    Back in the UK...!!
    yes comrade,
    well............hopefully after the next matchams practice i will start to strip the car, then of to the cage manufacturers, then painted again....and so on so ...........key word is HOPEFULLY
    ned to get the rar and front screens out.....and the rear one replicated in plastic.
  11. Andy_F
    Andy_F S13+S15=S28?
    Redditch/Solihull
    Sounds great Mat. Can't wait to see her in action.
  12. Dori Mat
    Dori Mat Active Member
    oxfordshire
    sounds good can't wait to see progress on this
  13. BenR
    BenR Member
    Sure can, but i need to know exact details of the engine to assertain the generation it is since toyota made several revisions.
    And the cams can be run with VVT or without, but i would suggest with VVT....bit of a pain to map, but on a turbo its highly beneficial.
  14. PhatBob
    PhatBob Ken Block???
    Newmarket
    Controlling them will be an issue, the degree variability that we can have with the BEAMS system means that I'd have to develop a complete new control algorithm which would need a map for each cam and a few different trigger cases. It would be an interesting task but would take a fair bit of developing.
    My thoughts on cam control are that we look at how the cam solanoids are pulsed and see if we can lock them in place electronically, if not then lock them mechanically until we're further down the line of development. Then get the engine set up and running before trying some noddy advance and retard tests (based on RPM and knock).
    Should be fun what ever.
  15. DriftLexus
    Back in the UK...!!
    its the altezza aluminum block 3s-ge,(sxe-10) with varible valve on the intake
    the control is by oil pressure and electronic, HKS do do a controler for the VVT called valcon, but id be happier to have it removed......or controled fully, its a infinatly varible cam, so not like vtec which is switched on/off
    to disable it, is a simple case of fitting a head gasket that blocks the oil drilling in the block
    i am currently looking at 2 turbos,
    a HKS GT2540R good for 370hp, and also a GT2835 good for around 400hp
    ill more than liekly run with external wastegate, if i use the gt2835
    Ben, you said your able to manufacture manifolds.......
    indeed fun....... :eek:
  16. BenR
    BenR Member
    I would need the cylinder head to take some measurements, as for that engine there are still 3 generations.
    I can make manifolds yes, inlet or exhaust?
    But complete car is needed to work out spacing.
  17. DriftLexus
    Back in the UK...!!
    ben, there is only one generation for the altezza,(sxe-10) the black top the red top is the dual vvti as fitted to the last generation mr2, the only other version i know is the type fitted to the caldina.
    as for getting you the head, thats not a problem.....i will be stripping it soon, to start the prep for the install of the 2.2 stroker parts
    the other generations are all the iron block 3s-ge, and gte as fitted to mr2 ,celica and avensis...plus other models
    however the Altezza and Caldina are the only cars fitted with the alloy blocks,
    the altezza also has the Yamaha developed head, with the titanium valves
    #17 DriftLexus, Oct 19, 2005
  18. tails
    tails Member
    north west london
    good luck with the rebuild mate :thumbs: any thoughts on rolling the arches??
  19. DriftLexus
    Back in the UK...!!
    the arches are rolled..........
  20. tails
    tails Member
    north west london
    soz just realised :o
