the lock thread
Thread in 'Drifting Chat / Pictures / Videos' started by Struggle, Mar 3, 2011.
  1. Struggle
    Struggle Active Member
    right thought i'de start up a lock thread.
    the idea is to post up a picture of your car on full lock (driving or stationary) and then list exactly what you've done to achieve what lock you have.
    this is just to show exactly what modifications gain extra lock and what difference it makes. just to help people out.
    ill be going for the DW knuckles for my next project (S14) and am hoping to have silly lock.
    but anyway i'll start off the thread.
    S13 with tein track rods & ends with the tein spacer fitted that came in the set.
  2. victim
    victim Bimmer Skidder
    Walsall
    Absolutely love that pic :)
  3. mitsi_matt
    mitsi_matt dorihomo
    overturned in a hedgerow!
    rack forward 20mm, tein rods & spacers, geomaster's, 50mm in lower arms.
    little more lock to come in the fine tuning!
  4. Struggle
    Christ thats silly!!!!! any side on pictures? 50mm in lower arms? explain.
  5. Clark3y
    Clark3y Member
    you can see the extension directly under the track rod end in the pic.
  6. Struggle
    you mean the lower arms are extended by 50mm?
  7. mitsi_matt
    mitsi_matt dorihomo
    yes, tbh 40mm would have been more sensible, at the moment the adjustable camber topmounts are pushed right out & i stiill have mega camber lol. ive not driven it as yet so will see how it goes before i do anything else.
    will get some piccys from the side/top today
  8. SX_BIG
    SX_BIG Active Member
    witham / Braintree - Essex
    so set a benchmark...
    i think i was on nearly full lock here on standard stuff
  9. Jaymo_sx
    Jaymo_sx Well-Known Member
    Still had a little more left in it i think
  10. Speedy9
    Speedy9 New Member
    Norway
    My old car.
  11. sulik
    sulik Member
    :smash:
  12. swiftmini
    swiftmini Active Member
    Not sure if either are on full lock, but I have more thani will ever need.
    Home made +35mm lower arms
    9j +5et 17inch wheels
    235 40 17 marangoni
    6.5* caster
    3.5* camber
    0 toe done by eye :wack:
    Homebrew knuckles with less ackerman, quicker steering, less included angle, 45mm roll centre correction, 55mm of bumpsteer correction. Took over 12months to get to where iam with them now :)
    Lengthened ikeya tie rods
    Rack forward +18mm
    I have geoknuckles to fit but iam saving them for a different project. After some quick rough measurements its has turned out that my own hubs are nion identicle, so I may as well leave the car as is and use them on my skyline.
  13. ndrifter
    ndrifter Member
    Norway
    Hachi with Battle Version Steering kit #2
  14. carlrst
    carlrst Member
    norfolk
    mine
    thats with modified knuckles, and one steering rack spacer, everything else standard, not baad tbh
  15. mitto
    mitto -NIGHTSPIRT FAMILY-
    - ALBION -
    why such an arse about cock way of doing it? 50mm? haha, good luck with that. you'll be stuck around 7* of camber.
  16. nissanr34cal
    mundford, norfolk
    loving that pic mitto
  17. Gaelen
    Gaelen New Member
    Coquitlam BC - Canada
    Full lock in the rain, stupid stock knuckles... thankfully I have some new ones sitting in the car waiting for this season!
  18. Clive
    Clive Active Member
    chichester, west sussex nr portsmouth
    mods:
    2 dw rack spacers each side...
    and
    yeap- i have over centre issues from the above "mod" lol
    slight anchor man (sp?) issues too :wack:
    modified knuckles, DW offset rack spacers and extended S14 lower arms coming soon :)
  19. Hudson.
    Hudson. JIBES
    Waterlooville, Portsmouth
    Who's modded knuckles are they man?
    Heres mine, tein rods and ends with spacer. S14 LCA and untouched s14 knuckles, 7* caster.
    Kinda want more but dont need it yet. Extra lock from standard saved my anus around Gerrards a few times though!
  20. diamondsink
    diamondsink Kyouto Drift
    Kyouto HQ, Bristol
    Superclarkey knuckles,
    rack moved forward 15mm,
    7mm rack spacers
    Modded and extended standard tie rods
    Now with 25mm extended lower arms.
    Modded tension rods
    And another little trick to the rack (10mm spacers!)
    You'll have to wait for a pic of that.
