Looking at lot people build and there do The scrub mod? What does it do ? And want bits do I need to buy from mst ? Help and pictures would be good thanks
Hey man, I'm assuming you are talking about the tweak for the MS / FS MST chassis? In short, it gives you better steering response for running CS. The bits you need are here... MST UK Aluminium spacer 3x5.5x1.0 MST RC drift cars and products and MST UK Aluminium spacer 3x5.5x2.0 MST RC drift cars and products you fit them like this... However, start out with one 1mm under the knuckle and 3mm on top of the knuckle It's also worth buying these... http://www.maxspeedtechnology.co.uk/5-8-ball-connector-x5.html so when you add the spacers you can use a longer bolt! Be careful not to use a too long of a bolt and crush the bearing inside the hub Hope that helps! Mitto
One of each will do you The silver spacer is just because I only had massive bolts! It's not for any other reason, although it does alter unsprung mass.
