For Sale is my Toyota Cressida LHD MX83. It has a 2jzgte cd009 swap running with e85 or pump gas. With the current setup made 750 HP and 690 nm on 27psi. Whatsapp 0039 328 9844551 Look for 29.000 euro Parts list: Aristo 2JZ-GTE Head Supra 2JZ-GE Block (No oil Squirters) OEM GTE Rods OEM GTE Pistons New OEM Timing Belt New OEM Tensioner New OEM Thermostat New OEM PCV Valve New OEM Gaskets, Seals New OEM MKIV Water Pump & Housing New OEM MKIV Radiator Hoses New OEM Oil Pump ACL Race Main Bearings ACL Race Thrust Bearings ACL Race Rod Bearings DM Power Steering hose DM Nuts and Bolts ATI Super Damper Underdrive pulley NGK BKR7E Spark Plugs Custom Intake Manifold Q45 Throttle Body Tial blowoff Power Steering Cooler JZX81 Engine Mount Brackets Ultra Urethane Motor Mounts IS300 Aluminum racing Radiator USDM intake Cam (7hp) Polished Valve covers Polished Intake Manifold Fuel Delivery: Injector Dynamics 1000cc Injectors Twin Walbro 255 Pumps HKS Dual Feed Fuel Rail Aeromotive FPR DM FPR Gauge DM Fuel Bypass Hose Russel In-Line Fuel Filters Summit -6AN Fittings Summit Adapter Fittings Summit -6AN SS Hose Turbo Gear: NEW (ONLY 1 month) Precision Turbo Equiptment 6266 t4 single scroll .84a/r Tial 44mm Wastegate T4 Reinforced Tubular Exhaust Manifold 3" Downpipe 3" Straight pipe 5.5" Duramax Exhaust Tip 4" Intake K&N Filter 3" Aluminum Intercooler 3" Aluminum Piping Silicone Couplings T-Bolt Clamps Kaizen -4AN Feed Line WFD -10AN Return Line Earls Fittings T4 Turbo Blanket 3" V-Band Clamps Drivetrain: CD009 NEW 3" ShaftMasters Drive shaft Xcessive Manufacturing MK3 Supra Diff Swap kit 3.73 LSD w/a locker Reinforced Subframe JZ Bellhousing ARP Flywheel Bolts MCrawler Shifter Bushings MCrawler Shifter Socket DM Full Clutch Hose MKIII Clutch Master Cylinder MKIII Clutch Pedal Assembly New OEM Slave Cylinder New OEM Clutch Hub New OEM Throw Out Bearing / Pilot New OEM Clutch Fork New OEM Fork Support New OEM Nuts / Bolts Redline MT90 Gear Oil ES300 Throttle Cable Remanned and Upgraded Alternator Electronics: ECU Master Full Standalone Computer ECU Master Oil pressure gauge ECU Master Fuel pressure gauge ECU Master Bluetooth adapter ECU Master boost controller 2 Tunes, Pump gas and E85 No gauges in the car Samsung Galaxy Note 10.1 inch Tablet This tablet and the bluetooth adapter displays all of the gauges New OEM Connectors Suspension/Wheels/Brakes: Cosmis Racing XT206R 18x9,5 et10 front 18x11 et8 rear Megan CoiloverS T3 Roll Center Adjusters Xcessive Manufacturing Front Lower Control Arms Xcessive Manufacturing Outer Tierods Xcessive Manufacturing Tension Arms Xcessive Manufacturing Steering Arms Xcessive Manufacturing Toe, Camber, and Caster Rear control arms Xcessive Manufacturing Dual rear caliper brackets Remanned MX73 PS rack Beech 300zx brake Adapters Extended Lug Studs D2 6pot caliper 300mm disc aluminium rotor semifloated Stainless steel braided brake lines Summit Battery Relocation Kit Rear Access Battery Cut off Switch Nardi Classic 165mm Leather 6K Hi/Lo HIDs Awesome Broadway Rear View Mirror Authentic Bride Lo-Max Seats Sparco 4pt Harnesses 6pt cage built to FD specifications Full interior in the front except carpet Painted cage, bed liner on the floors Handmade bodykit {}
