Toyota Soarer 1.5jz Borg R154
Thread in 'Drift cars for sale' started by doninphi, Mar 3, 2021.
  1. doninphi
    doninphi Member
    Lincoln
    I think its time I moved on. I'm still so hot and cold over this decision so I'm going to list. And see what happens. The car will be taxed for March so if you're interested you can come see/get a ride. No time wasters.
    Many images and video of the car are here:
    For Sale. Toyota Soarer 1.5jz single turbo r154 car. Owned it 8 years. I've spent a fortune (haven't we all) and have every receipt and many to show its life too. Every MOT and huge volume of paperwork. The car is modified in pretty much every way but in a way that is sympathetic and I tried to build a 'complete' car rather than just looks over interior and every other aspect.
    Car spec/good bits: Engine: (no graph. Goes like hell. Told by fuelling map its around 450bhp 500ft and I certainly don't need more.) 1.5jz build.
    2jzGE bottom end fully rebuilt with all new bearings and seals. Block washed.
    1jz Head skimmed washed.
    New valve guides.
    Stem seals.
    Shimless buckets.
    Cometic 2.3mm head gasket
    New water pump.
    New oil pump.
    Deatschwerks dw200 fuel pump
    Fuel filter changed 3 yrs ago
    Borg Warner s362sxe
    Funk motorsport heat shields
    Tonnka manifold from Aus.
    Stainless system 3" turbo back Stainless screamer
    45mm Turbosmart latest gen wastegate
    550cc injectors with ballast
    Intake Heat Sheild
    PKD Slam Panel Shield
    K&N 8″ Induction Cone & Hard pipe
    Mishimoto intercooler
    Mishimoto X spec Supra uprated aluminium radiator
    Link Storm ECU mapped my Tom at Fensport
    Carbon coil pack cover
    Clear pulley cover
    Chassis & Drivetrain:
    R154 converted
    Xtreme clutch R154 fly was ground flat before install
    New clutch master cylinder
    PKD BMC Stopper
    Cusco carbon strut brace
    A01B Limited Slip Diff
    HSD coilovers (medium hardness)
    Crimson,Inc Linea L450 alloy wheels – 19×9 et16 and 19×10 et23 Uniroyal Rainsport 3’s all round – 235/35r19 front and 25/35r19 rear
    LS400 Front callipers and custom calliper spacers to fit 360mm ISF discs
    EBC Red stuff pads front and rear Red braided brake lines
    Interior:
    The interior below has been fully retrimmed in Leather and Suede with red stitch details
    Nardi black leather and grey stitch wheel
    Popformance Touch screen air con
    Supra facelift front seats
    Gunmetal mat set
    Pioneer touch screen double din headunit FLI rear speakers
    Pioneer sub and amp in custom made box (spare wheel well, spare wheel removed)
    Pioneer sub cover OEM
    Soarer boot mat (with hole cut for sub!)
    Exterior:
    Rolled arches to fit wheels
    Stock front splitter
    35% tinted rear side and rear windows
    94-98 spec rear lamps
    HID 6000k main beam and driving lamps, LED sides to match
    96+ copys of factory side skirts
    GRAMS rear carbon diffuser
    SEIBON carbon rear bootlid
    Custom made carbon OEM style rear spoiler
    I could have forgotten more bits. Its a big list!
    Bad bits. Being totally honest its a 30 year old car. As such it could still do with more things (im a bit ocd) paint is as I got it. Its well looked after but has a small rust bubble on left wing about 20p sized. And rust across the top of the windscreen which I've treated and covered in paint then matt black vinyl so seal it.
    Has a gentle rear knock on hard accel. Checked lots. Could be diff bushes. Changing drop links before sale.
    118kms on clock. Not converted to miles. Serviced yearly no matter the miles I did. Paperwork to prove. Its been 2 yrs since all the engine and box work and its probably done 3k since. So its settled in nicely.
    £14k ovno.
    156695393_10165332237910323_3513742644409937086_o.
    156639938_10165332237875323_487176777940126870_o.
    156695393_10165332237855323_8620799933731102971_n.
    156595252_10165332237885323_630344063441046809_o.
    157113929_10165332237890323_6629709850267050941_o.
    156291194_10165332237905323_1156379562421673161_o.
    156577435_10165332581355323_1188413455857917173_o.
    156606632_10165332581375323_5570619504361424973_o.
    156694035_10165332581400323_1700972765366660092_o.
    155783099_10165332581450323_7455249688796074888_o.
    156740974_10165332581475323_5687422441176637695_o.
    156228937_10165332581505323_9155195143979704822_o.
    156598792_10165332581530323_4348488786332922468_o.
    156732920_10165332581555323_2998456513333413874_o.
    157061089_10165332581580323_8287420937727135957_o.
    156222809_10165332581655323_457940781781432555_o.
    156233371_10165332581650323_7116071779284491049_o.
    156775316_10165332581715323_6796673347710748034_o.
    • Winner Winner x 1
  2. doninphi
    doninphi Member
    Lincoln
    Car is in Lincoln
    #2 doninphi, Mar 4, 2021
  3. Retz
    Retz Member
    Birmingham
    Awsome car
    And the owner is a legend
    Buy with confidence!
  4. doninphi
    doninphi Member
    Lincoln
    Sold pending collection
  5. doninphi
    doninphi Member
    Lincoln
    Sold
