For Sale Toyota Vitz RS Turbo
Thread in 'Misc for sale' started by Tommy59, Dec 27, 2019.
  1. Tommy59
    Tommy59 Active Member
    Milton Keynes
    2004 Toyota Vitz RS Turbo by TRD
    150PS
    970kg
    Manual gearbox
    60k miles
    LSD
    £5995
    JHADmMUgA2dp7x7bjRVcA1G1p92RkGRPTVa834GGoSBcND_5BpVtk8fRExSMmYyRGyV1BDVLiXUO6KnajQ=w1250-h937-no.
    Produced in limited numbers in Japan, the RS Vitz was fitted with a turbo charger kit from TRD by specialist dealers in Japan. This is a Modellista spec with all the supporting documents from Modellista dealership in Chiba Japan. Along with the turbo Toyota fitted larger injectors, a larger radiator, an oil cooler, ducting for the top mounted intercooler, modified the ECU among other changes.
    This is one of the best examples of a Vitz RS Turbo I've ever seen with lower mileage and more JDM options than I've seen on any Vitz.
    It was imported into the UK in October 2019 so it's a fresh import and I'm the first UK owner. As it's a fresh import the underside is immaculate without a hint of rust. When I took delivery of the vehicle I changed the engine oil, replaced the oil filter and swapped the spark plugs out for new ones along with giving the whole vehicle an inspection and thorough going through. The paintwork on the sides of the vehicle is immaculate but there is some clear coat damage on the roof and bonnet which could easily be rectified.
    The tyres have just been replaced with brand new Michelin's.
    Recent MOT with no advisories.
    Unfortunately I need a larger vehicle and it's with regret that I have to put this up for sale as it's a great car and without a doubt the ultimate version of the Yaris/Vitz. I was planning to keep this for a long time and no expense has been spared in the time I've owned it or it's previous life. Due to the rarity, low mileage, modifications and excellent condition this would make an ideal investment.
    This car comes with a service history from Japan which in itself is rare but it also comes with documentation for all the modifications carried out in Japan, each one has been carefully documented and noted in ring binders. Based on these and my findings the modifications are as follows:
    Suspension:
    Full Modellista Bilstein suspension
    TRD front upper strut brace
    TRD rear upper strut brace
    Front lower brace
    TRD rear lower brace
    TRD rear beam reinforcement
    TRD spring seats
    C-One Motorsport front anti-roll bar
    Driveline:
    TRD factory LSD
    Glanza 3.7 final drive
    TRD clutch
    TRD short shifter
    Braided clutch line
    Brakes:
    Endless brake discs
    Endless brake pads
    Swage braided brake lines front and rear
    Exterior:
    Titanium Modellista back box
    Factory HID headlights
    Vitz RS bonnet
    TRD front bumper lip
    TRD rear bumper lip
    Interior:
    Sparco pedals
    Blue tinted wing mirrors
    Super accelerator pedal
    LED ignition ring
    Two sets of RS floor mats
    Toyota colour changing speed meter
    Cubby covers
    Engine & Others:
    Cusco brake master cylinder stopper
    Front wing braces
    Catch can
    Speed delimited
    Toyota earth kit
    I will be keeping the head unit so it does not come with the car.
    With all the modifications and the standard power it is one of the best handling cars I've ever driven and it's more than capable of upsetting much bigger cars! I'll be sad to see it go but I need something larger and more practical.
    No tyre kickers or test pilots. You won't have full insurance to test drive it so I will be doing any test drives with you in the passenger seat.
    Payment by bank transfer
    #1 Tommy59, Dec 27, 2019
    • Like Like x 2
  2. Tommy59
    Milton Keynes
    WkPLaIAWxCAYISMvdlYdawUJczBzEzCBssl3xvNVY8hpQ4f2uCdasqESKPot8IBBKtXP1EQ6-wxUDUO4kw=w1250-h937-no.
    J2v-LVEyvkhbNrt-FFN3-59D0XR3W7trqC3J8bMcnEY6VXIIo9WLHZ3Eeznd-NwiLDHKpRl4gLsqfkleZQ=w1250-h937-no.
    3wT8PI0Mal4XjRzHB7Ws9-gwKIpIkhXmIofDRKevfosrQSPXTKX7Yl_XTl71ZMnJIiVeRENxrBtV6Hd1Bg=w1250-h937-no.
    xPDW5O8A7wxfCsHtLI-vqLKM7eWQ4ZAFpMsRnEf_dSi_kfABk5spqXkJhU-gzv36k4cEApHhlRBmP2Ueew=w1250-h937-no.
    J6fDgoxp0dXu_FobCDc-0N43H71nyXr5m8JxkuTtT_Xhhq928oPF8iG9Hg7BTUBDq2cjcuVNBSXZrq9d1Q=w1250-h937-no.
    66iYKJHIMJ8pafArfLWdiqyCHTiVe1VjS8iog5ACyh2hxQHMDroRqPIp4zqRQn3JwqcdHtIkM11Vc5iIZw=w1250-h937-no.
    Xa8AosDoLpO9lIuLP9B7zjQ6O9qsvt2qmfZVamPcKR3AoxPvEwtjus109Evv5nAKwJT5BjF98nXkIaQLQA=w1250-h937-no.
    SOAzkp_9ltP28OHRQQt_mXACkBtvc11G2nDGmXw1BmxKQVMhF6iYwO-kGX7TSlXXY2LOX9JYowOyJoQxhQ=w1250-h937-no.
    Ob_KTYCcWx2ATOgh2TNTSLIkryPuIEUJlTQ9aOhKxDyjhOahce2O7lNsY2UP1_YmhGRbP7GpJBcJC0HKJg=w1250-h937-no.
    • Like Like x 2
  3. littlegriggzy
    littlegriggzy Member
    Cambridge, UK
    Would help to put a price fella
  4. Ashley Fellows
    Ashley Fellows New Member
    Dudley
    did you sell your car.
  5. Tommy59
    Milton Keynes
    Yeah it's gone bud!
  6. Ashley Fellows
    Dudley
    ok,no worries ,i nearly brought it last year off the importer but you bet me too it.Still got over 100 pics they sent me on it.
