For Sale Turbos for sale (G25-550/2871R/2860R Gen2)
Thread in 'Parts for sale' started by Jay1017, May 17, 2021.
  1. Jay1017
    Jay1017 Member
    Dudley
    Selling some of the turbos I have on the shelf, all are recently built and brand new ready to use
    G25-550/GT28r Hybrid Turbo - £800
    Specifications:
    - G25-550 9+0 forged billet compressor wheel
    - Inconel GT28r turbine wheel
    - Brand new bearing housing, ceramic ball bearing cage & seals
    - Brand new turbine housing, internal wastegate has been ported to improve boost control
    - Machined T28 (GT2560) compressor housing
    - Built in 1mm restrictor
    - Component & VSR balanced
    56-EA8092-E37-D-44-B9-B36-B-0-E5-FEECA66-D2.
    5141-FCCE-9-FCA-45-F0-AD59-1-B78-CA6-BEB28.
    Compressor size: 48/60mm
    Turbine size: 53.8/47mm
    Turbine housing is T2 flange with 5 bolt outlet (.64ar)
    Rated for 400hp with quick spool, performing nearly identical to an actual G25-550. Direct bolt on for SR20/CA18
    GT2871r Hybrid - £720
    Specifications:
    - GT2871r 6/6 high flow billet compressor wheel
    - Inconel GT2871r turbine wheel
    - Ported internal wastegate to improve boost control
    - Reprofiled & polished GT2871r compressor housing
    60-FFB879-EA09-4-D8-C-A897-1-A70-F6-B206-C5.
    2-D164-F54-7-F57-4-BE4-9910-12648-C783024.
    Compressor size: 51/71 (76mm extended tip)
    Rated for up to 450hp with improved spool up characteristics over a standard 2871r. Direct bolt on for SR20/CA18
    T25 converted to GTX2860r Gen 2 - £750
    Specifications:
    - GTX2860R G2 compressor wheel
    - Inconel GTX2860R turbine wheel
    - Reprofiled T25 (GT2552) compressor housing
    - Pressure tested & powdercoated stock actuator (10psi)
    1-BDD4-E39-87-E2-4-E16-80-A8-124311825-E7-C.
    Compressor size: 46/60mm
    Excellent for smaller displacement engines, providing excellent boost response being the smallest GT28 frame unit while still being capable of making up to 400hp. Bolt-on fitment for SR20 & CA18
  2. Jay1017
    Jay1017 Member
    Dudley
    2871r SOLD
  3. Jay1017
    Jay1017 Member
    Dudley
    Bump, GTX2860rG2 still available, £730
    G25-550/GT28r also still available, £780
    #3 Jay1017, May 25, 2021
  4. Jay1017
    Jay1017 Member
    Dudley
  5. Jay1017
    Jay1017 Member
    Dudley
    Bump. G25/2860 still available
