Hey guys I have a few turbos for sale that are just sat on the shelf gathering dust Garrett GT2871r Hybrid - New The spec of the turbo is as follows: - GT2871r 6/6 High flow billet compressor wheel - Inconel GT2871r turbine wheel - Brand new bearing housing, ceramic ball bearing cage & seals - Brand new turbine housing - Ported internal wastegate to improve boost control - Brand new seal plate with o-ring - Reprofiled & polished GT2871r compressor housing - Built in 1mm restrictor Compressor spec: 51/71-76mm 34mm height Turbine spec: 53.8/47mm Turbine housing is T2 flange with 5 bolt outlet (.64ar) Rated for 450hp - £720 Garrett GT3071r - USED Good used condition Garrett GT3071, has a crack around wastegate flapper but doesn’t affect use. Compressor spec: 53/71mm .86ar turbine housing (T2, 5 bolt outlet) £500 Garrett T25 (GT2552) - Freshly rebuilt Spec of the turbo is as follows: - Inconel turbine wheel - 360* thrust bearing upgrade - Updated brass journal bearings Compressor spec: 39.8/51.4mm Turbine spec: 42/53mm Turbine housing is T2 flange with 5 bolt outlet (.64ar) OEM Actuator included Rated for 240hp £260 Volvo TD04H-13c - Freshly rebuilt TD04H to suit a Volvo 940 (may fit others) - Inconel turbine wheel - Replacement compressor wheel - New bearings & seals throughout Not really sure what it’s worth as I’ve never seen one for sale, it also doesn’t owe me much. £200
