UK's most prolific JZ S Body - Heritage inside!
Thread in 'Drift cars for sale' started by Dylan, Oct 31, 2013.
  1. Dylan
    Dylan JZS14FTW
    cheam/sutton
    This has become bit of an ornament in my garage, so its time for someone to really make use of her..
    History – The first car was UKs first 1JZ powered S14a being completed and driving in Mid 2008!
    2007 engine was sourced; complete engine gasket kit, head acid dip, re-lapped valves, new water pump, belts, tensioners etc etc. Ran 15,000 miles and competed in UK BDC 2009 as a standard TT at 301bhp flawlessly! It put me into 3rd place overall in semi-pro 2009.
    2010- present. The old shell was scrapped as I had been offered a minter, so it was decided to build up a tidier shell and revisit the powertrain. The power was upped to 490~bhp and ran flawlessly for another 25,000 miles till only few months ago. Electrical issue caused premature failure, and the cylinder head had to be rebuilt. The rebuild included ARP head studs, Tomei 2.0 mm HG, new tensioner, stem seals, and various gaskets and seals on the engine.
    The car was re-mapped about 2 months ago by Greg (the only person to tune my engine) and it now makes 475~ bhp & 485 ft/lbs @ 1.4 bar. Greg had spent a lot more time on the throttling of the map, so the throttle response is unreal now, its never felt this lively before!
    I have already used the car a handful of times since mapping and feels like a completely different beast!
    The shell was built up from a 97 BARE shell – This has to be one of the cleanest 14a’s ive ever seen, hence the choice to re-shell into it. Upon the build up I used POR 15 (Marine rust protectant) on all the seams on the underside, then stone chipped.
    The car has had a few bumps/nudges over the years, but nothing major. Some damage to the front flinch areas. But these can be cut and framed prior to sale for the right price if it bothers you that much.
    Welcome to measure up the chassis yourself, or full underbody viewing in my pit.
    Suspension
    Front PBM Tension Rods
    Modified lower arms with shimable lockstop and reinforcement gussets.
    Energy Suspension lower arm bushes
    Poly steering rack bush
    PBM Uprights for extra lock and faster / precise steering feel
    Ikeya Formula track rods and rack spacers
    Recently Replaced OEM track rod ends
    DW CS1's in good condition (Front damper adjusters are stuck atm)
    A31 Cefiro ARB
    SM 6061 Subframe risers
    PBM Camber arms
    PBM Rear Toe arms
    OE Rear Knuckles, lower arms & Subframe all painted.
    OE S14 welded diff and shafts
    35mm rear bolt on spacers
    Body & Exterior
    Seam welded bay
    Tubbed arches front and rear
    Aluminum bumper armature and slam panel.
    POR 15 on all seams and then stonechipped underside and wheel arches
    Fabricage 6 point bolt in cage, with double door bars + gussets meets all regs BDC, EDA, etc (Cage has been sprayed red) Door bars have been powder coated.
    R33 GTS brakes all round including cable operated drum handbrake
    Project Mu NS front pads
    OEM Rear pads
    Braided brake lines on calipers
    All original rigid lines have been replaced with Nickel Copper brake pipe
    AP Brake proportioning valve (normally run 90% brakes on front for drifting) perfect for LFB!
    Custom headlight air duct driver side
    Passenger side opened and painted
    Both fitted with HIDs
    Monkey magic front bumper with Dmax corner indicators
    SM Vented Bonnet
    Modified Chargespeed front wings to single vent
    DMax Type 3 sideskirts
    Chargespeed overfenders
    VX Rear bumper
    Dmax Roof spoiler
    Smoothed S14 bootlid with S14 colour coded centre light panel
    Bonnet and boot on external latches
    Recent full car re-spray in KH3 Black
    Candy red base coat with red flake in roof.
    Interior, engine bay and body has been painted KH3 (Car was originally AJ4 Red)
    Custom wiring loom to move fuse box inside car
    Only a small loom passes through the drives front arch which is for just the lights only, and has been routed to clear wheels.
    Engine is on a separate harness passing through the bulkhead
    Interior
    Bride passenger seat on DW super low sliding side mount
    Spaco Evo Drivers seat on super low Bride subframe
    FIA Ricco 4 point harnesses for both seats
    Honda F1 Dry carbon switch panel
    Works Bell GTC-R tilt steering wheel (will not be sold with car)
    Super gangster steering wheel with CNC machined adaptor and spacers
    Plumbed in FIA fire extinguisher with pull cords (Serviced this year so good for another 5 years)
    Handheld foam extinguisher attached to roll cage
    Battery isolator kill switch
    Aluminium firewall.
    No Carpet
    Part door cards, with full electric windows and mirrors
    Even has a radio and speakers for waiting in the Q like a boss :p
    Fuelling
    OE Fuel tank,
    2L AH Fabrications surge tank
    255 Walbro in tank pump
    Bosch 044 inline pump
    Sytek Motorsport serviceable fuel filter.
    10mm feed and return rubber over braid (Been planning on changing these to Nitrile but never got round to it)
    Aeromotive 'style' Adjustable FPR with gauge
    Combination of Aeroquip and Pirtek fittings throughout.
    Fuel pumps are wired so each pump can be controlled independently for serviceability, draining, flooding etc.
    Powertrain
    Rebuilt 1JZ-GTE sitting on super low 1JZ to S14 mounts (just look how low this engine is compared to all the other JZ S bodies ;)
    Block has been de-greased and painted on first rebuild
    Polished rocker covers, modified with breathers
    Front sump (with shallow ribs so no clearance issues on steering racks, some front sumps have deep ribs which can cause clearance issues)
    ARP Head studs
    2mm Tomei Headgasket
    Re-seated valves & shimmed head – Leak down tested
    New gaskets and seals throughout inc F & R main seals.
    Thermal Intake gasket (Greg noticed a significant improvement to intake temps with this fitted)
    Water pump
    All ancillaries
    Mishimoto 65C thermostat
    Evolution 10.5lb Lightweight Flywheel with serviceable core + spare core
    ACT Xtreme 6 puk clutch rated to 650 ft lbs.
    New OE slave cylinder
    Japspeed manifold
    T4-T3 tapered flange adaptor
    GSR HX35
    GSR HKS style wastegate
    SM Custom T304 wing exit screamer pipe (Graphite heat wrapped)
    SM Custom T304 3” downpipe with 2 flexis (horizontal & vertical axis) (Graphite Heat wrapped)
    SM Superlow T304 3” exhaust system, with two switchable back boxes (Stealth system will meet every noise reg for any UK track, and the shotguns well they don’t need no explaining) Can be swapped in less than 2 minutes!
    Power Enterprise 550cc injectors (been ultrasonically cleaned and flow tested 3 years ago and 1 month ago prior to mapping) Includes 1 spare.
    Deleted IACV
    Artel motorsport silicones throughout
    Upside down APEX IC
    Shortened pipework (2 pipes 4 joiners)
    AE 30 row oil cooler and relocation kit
    Custom power steering cooler
    AE 60mm rad with Toyota OE twin electric fans with sealed aluminium shroud (A combination of this and the thermostat has resulted in super cool water temps even after prolonged use)
    Custom oil breathing system, with divided collector catch can and recirc into intake
    Pipercross custom monster air filter – Has two mounting options one in bay directly behind headlight, or bumper vent mounted.
    LS3 Coilpacks mounted on another piece of Honda F1 Dry Carbon.
    KV85 Magnecor HT Leads
    3 bar External map sensor
    Haltech Sprint 500 ECU and SM engine harness
    Most recent map made 475bhp & 485 ftlbs @ 1.4bar
    HKS EVC 6 Boost controller
    AEM UEGO Wideband with gauge
    SPA Design dual temp gauge for oil and water
    MC Shifter bush
    Genuine Toyota bellhousing
    R154 currently filled with Redline MT90.
    Recently replaced gearbox rear seal
    Engine has only ever been run on Mobil 1 Motorsport 10w 60 since the first build. (I’m quite happy to whip of the cam covers to show you how mint it is inside)
    Car will be sold with a service and alignment, ready to enter any UK & Euro comp,
    No doubt ive missed a few bits and bobs, but i'll add when i remember.
    Like any drift car, it has a few rough edges here and there, but like every car ive sold im more than happy to point out every little detail. For this sort of pedigree car, I’d feel more comfortable that the new owner knows every little thing about it.
    NO PX's
    Price £11,991 – No wheels!
    07751203302 as im not on here much. Please don't text me asking to swap for your S13, or what the lowest i'll take. If your serious ring me.
    I know there are a few JZ S bodies priced around this mark or under, but what you need to remember is: the quality of some of the parts are second to none (a huge amount of thought and care) has gone into the complete driveline to ensure the reliability which has really prevailed over the years, and the development that has gone into this car. The shear mechanical grip this car can achieve is quite suprising. More than happy to offer aftercare/support on the vehicle.
    Currently the car is setup for an extremely high level of grip normally run on semi-slicks all round at low 18 – 24psi. The grip is so much that the reliability of the drive shafts has been compromised even with the raised sub frame. I’d advise if this is to be used with semi-slicks to upgrade the rear shafts/diff. However part worns, or medium compound rubber will be fine.
    Willing to export!
    Ive got hundreds more photos, these just happen to be recent ones.
    #1 Dylan, Oct 31, 2013
  2. Dylan
    Dylan JZS14FTW
    cheam/sutton
    Previous build threads.
    http://www.driftworks.com/forum/drift-car-projects-builds/71236-slidestars-1jz-s14.html
    http://www.driftworks.com/forum/dri...rs-scorpion-motorsports-sjs-design-jzs14.html
    The last one is very out of date, and a substantial amount of changes have occurred since.
    Few vids of it in action
    [video]vimeo.com/13111917[/video]
    [video]www.youtube.com/watch?v=Fb21lCTT5B0[/video]
    [video]www.youtube.com/watch?v=QkgJM0fhhEY[/video]
    [video]www.youtube.com/watch?v=NZZBjAPCWHQ[/video]
    [video]www.youtube.com/watch?v=pOLZqZk8v9Q[/video]
    [video]www.youtube.com/watch?v=FFXM1wCHj_g[/video]
    Lastly, like with any of my cars, if you can recommend/share and lead to a successful sale, you will receive a £300 commision ;)
    #2 Dylan, Oct 31, 2013
  3. initial_j
    initial_j Made guy
    Ashford, Kent
    aw man! literaly one of the best s bodies in europe! jealous i dont have the funds right now!
  4. 192_Nightmare
    192_Nightmare Member
    Sutton Surrey 4 Now
    How much is it? Sorry if it's in the add but I can't seem to see it cheers
  5. Dylan
    Dylan JZS14FTW
    cheam/sutton
    Thanks Jack :) Gutted to sell it tbh, but something more menacing awaits ;)
    circa £13K
  6. Hudson.
    Hudson. JIBES
    Waterlooville, Portsmouth
    Can vouch for this being awesome having seen it regularly in the flesh.
    Dylans a top dude and 100% genuine, you wont be let down!
    Good luck with the sale mate.
  7. pazza10
    pazza10 Member
    Nice to see its still on my old advans. Awesome car man
  8. dan200s14
    dan200s14 Member
    Shepton mallet / wincanton
    I can't believe you are selling it Dylan but glwts. I can't even imagine how your going to feel when this drives away under new ownership!
  9. royal
    royal S1- F.T break!
    If I was buying a drift car then this one would be a certain, it's an absolute beast. Gutted it's going Dylan but looking forward to what you build next.
  10. dale_b
    dale_b #DriftFactory
    Surrey UK
    Nicely written advert dude:thumbs:
    I too can vouch for this car being awesome.. It was a passenger ride in this car that got me into drifting in such a big way, I bought a 1j the very next day, Iv basically copied most this setup on my car..
    Iv also lent a hand in various strip downs and rebuilds of this in the last year or so, so much 'next level' things on this car.. It hasn't been 'built'.. It's been Engineered, to a high standard..
    Sure this won't hang around..:thumbs:
  11. tooley
    tooley ドリフトキング
    Coventry / Swansea
    Good luck with the sale Dylan!
    This cars is a total monster and amazingly set up!!!! Some one buy it!!!!!
  12. jamesb16a2
    jamesb16a2 Member
    oxford
    same story here lol saw dales car got me into drifting again . met dylan real noce guy genuine gent too . if only i had the pennies .. glwts dude :]
  13. Dylan
    Dylan JZS14FTW
    cheam/sutton
    Thanks for all the kind words guys! We will be at Lydden on the 30th Nov, if anyone wants to come view it or see it in action ;)
  14. Stavros
    Stavros Active Member
    Isle of bollocks
    Great value car for the money, one that's been built properly so it's proven to be strong and reliable and effective- A lot better than buying a big spec unreliable heap like most cars!
    Love it, a great buy.
  15. geoffersmaher
    geoffersmaher indecisive
    croydon massive
    the quality of this car is retard, dylan does not skip anything
    people this is a bargain
  16. Dylan
    Dylan JZS14FTW
    cheam/sutton
    Really blown away with all these comments. Took her for a blast at the weekend, and everytime i drive it, i think twice about selling...BUT she must go... :(
  17. MW99
    MW99 Member
    Camberley, Surrey
    Massive bump for a massively awesome car! You know my views on it dude! Definitely be sad to see it go! Wish I could fund this car!
  18. Dylan
    Dylan JZS14FTW
    cheam/sutton
  19. haza88
    haza88 Active Member
    ya mumas
    mental car seen it in action quite a few times
    very good buy for some one
    free bump
    - - - Updated - - -
    free bump
  20. NORFY
    NORFY Active Member
    faversham, kent
    Absolutely awesome, been around this from way back in the lydd days, cant believe its up for sale. End of an era.
    This is hands down one of the best cars in the country, bag a bargain.
