Hi there is a BMW E36 with what is said to be hydraulic driftworks. Wilwood .625 Cylinder Slides Etc The hydro system won't lock the wheels and takes a little bit of force to do so, other times it's okay depending on the surface etc. When I first bought the car, the hydro system discovered over time it got worse. Is this a simple bleed case or will the fork be adjusted if so in what direction? A few times I pulled the wand into an entrance and it didn't lock and just slowed the car in places like other times with no problem at all. Looks like it takes more force to lock than before. Good pads, etc. Thanks in advance
