Unorthodox method: unseizing a coilover with coke
Thread in 'Technical Questions' started by pitesy, Jan 21, 2012.
  1. pitesy
    pitesy Member
    Hungary
    Hi!
    As above. Having difficulties with unseizing mine. Tried the spanner, with leverage, WD40 for 3 days, nothing.
    Read threads about derusting them with coke.
    For example:
    Ways to revive rusty coilovers? - Scionlife.com
    So... Until it doesn't meet rubber parts, is it safe? It's a s14 cusco coilover. Threads are perfectly clean, no rust at all. Other parts are in a good condition aswell. (no rustbucket :)) But I guess nobody adjusted it after installing and haven't used any lubricant to prevent corrosion.
    So coke? :) I have now a few liters at home. Opinion? Anybody tried?
    Cheers!
  2. FireStorm999
    FireStorm999 Active Member
    im going to try it as well as i used WD for 3 hours with a huge hammer and nothing i cant adjust the height.
    next weekend im going to use coke. dont use the cheap stuff as its not got the acid that coke has.
  3. milez
    milez Active Member
    wellingborough, northants
    i used battery acid last time that worked a treat lol
  4. FireStorm999
    my HKS coilovers have the damping adjustment on the bottom, will this bit be alright submergeded in coke?
  5. Clive
    Clive Active Member
    chichester, west sussex nr portsmouth
    leak to soak over night in a bucket of diesel :)
  6. FireStorm999
    See above still clive, even if i used diesel, can you submerge the damping adjuster thats on the bottom.
  7. pitesy
    pitesy Member
    Hungary
    Well I have cheap coke now... But it says in the ingredients: phosphorous acid. They say this acid and carbon dioxide does the trick. I hope at least. Anybody else tried it maybe? :)
    #7 pitesy, Jan 21, 2012
  8. pitesy
    pitesy Member
    Hungary
    Bump..
    Personally I'm afraid of battery acid. Cusco says on the website the threads are zink coated. Would acid melt this coat?
    Some progress... Tried coke with rusty bolts first, well.. Not very impressing. Maybe I should try diesel aswell.
    FireStorm999: could you "separate" the adjuster part with a few layers of foil/plastic wrap/something and (duct) tape?
  9. MrLuke
    MrLuke #172
    Cambridge-ish
    Vinegar is another one to try. It is an acid and does a pretty good job.
  10. FireStorm999
    @ pikey
    the adjuster is on the bottom like this
    and the big bit that adjsuts the height is seized solid.
    so i was gonna submerge this in the bottle - ie cut the coke bottle in half and just sit the coilover inside overnight.
  11. pitesy
    pitesy Member
    Hungary
    MrLuke: Vinegar.. Sounds good! I'll try it with the rusty bolts first, we'll see how it works.
    FireStorm999: I meant the duct tape/plastic wrap like masking. So basically you wrap that lower part to protect it from the fluids. That part isn't threaded, so it's not a must to have contact with coke/diesel/etc. Maybe I'm wrong, just guessing. :)
  12. 4_Stroke
    4_Stroke Member
    Leicester
    After soaking in coke/vineger etc wash off with boiling water from a kettle. the adjuster is aluminium and will expand more than the strut tube. It will help loosen the ring.
  13. FireStorm999
    sorry unlike that picture mine has thread the whole way down to the bottom.i need to submerge the bottom adjuster (purple nobby thing), and am wondering if thats ok. i will obviously wrap it up as much as possible.
    the rears will be fine to submerge as the adjuster is on the top.
    its the one front coilover thats screwed
  14. pitesy
    pitesy Member
    Hungary
    FireStorm999: Ok, see it now. :)
    Well think about it. That part is in contact with water, mud, salt, etc. all the time while you drive. So in my opinion it shoulnd't be a problem. Okay, rain and soaking is a different game, but I don't think it would be a problem. Theoretically it's a fully closed system. Right? :)
    4_Stroke: Hot water makes sense to me.. Unlike heating with fire. :)
    Thanks for the ideas everybody! After I broke them loose, I'll write which method was successful. :)
  15. FireStorm999
    thanks for your reassurrance, il give this a go on the weekend, remove friday night and let them soak overnight in coke for fitting sat morning.
    if you find something is better in the mean time let me know.
  16. BreadBin
    BreadBin Rough Tonguer
    Wiltshire
    WD40 is useless for unseizing stuff. PlusGas is the shit :nod:
  17. pitesy
    pitesy Member
    Hungary
    FireStorm999: Cheers! Mind: it's just my opinion, maybe I'm wrong. Tomorrow I'll try a few things, so I'll let you know if something was successful :)
    BreadBin: Too bad we don't have PlusGas in Hungary... :S Do you know about similar products maybe? We only have Liqui Moly Ceramic Rust Solvent for example.. I don't know if it's any good. Thanks!
  18. gaz_moose
    gaz_moose .MTM.
    round a bend
    coke wont do anything. ive tried it. soak them in some kind of penetrating oil or diesel. id be tempted to seal the lower adjuster aswell.oil does funny things to rubber.
  19. Rhys_sx
    Rhys_sx -NightWalkers-
    Cardiff, South wales
    use cheap coke all the time, great for cleaning carb jets , de greasing parts , even unblocked a radiator with it
  20. eurodave
    eurodave Member
    Northern Ireland
    well surely its exactly the same as cleaning coins? i used to clean coins for my grandad with coke, worked REALLY well, the dirtier they are the longer you have to soak them tho.
    i can see there being any problems with the bottom of the coils, they are surely watterproof? they are outside the car and deal with puddles, floods etc?
    might do this with the coils that i have coming, wanna get them clean before they go on :D
