Volvo 340 1.4 To F7P Swap
Thread in 'Drifting Chat / Pictures / Videos' started by Adam2012, Oct 12, 2012.
  1. Adam2012
    Adam2012 New Member
    Hartlepool
    Hi,
    Just wondering I have a volvo 340 drift car but its only a 1.4 would a f7p be a straight swap because i hear you must use 1.7 volvo parts to be a stright swap. sorry i'm new to this but thanks in advance:)
  2. Cheshire190e
    Cheshire190e Active Member
    Macclesfield
    Hi mate, welcome to driftworks!
    If you used the search you would find all the information you need to know. I'm afraid to fit the f7p you would need the bellhousing and subframe from a 1.7 as the 1.4 block is completely different.
    I'm not sure what else you would need but its been done many times on here. Good luck
  3. Adam2012
    Adam2012 New Member
    Hartlepool
    Thank you and will do
  4. Max-san
    Max-san Member
    Brands Hatch
    That! Were abouts are you from?
  5. classicswede
    classicswede New Member
    No the volvo does not have a sub frame so you don't need that. The crossmember is the same.
    From the 1.7 you need,
    bellhousing,
    sump,
    flywheel and clutch,
    engine mounts with brakets (x4)
    alternator bracket.
    Think that is about it
