R35 GTR VR38DETT injectors into a R32 GTST RB20DET? I'm after some info. I've been advised to upgrade the injectors in my R32 and one type that had been mentioned is the injector found in the R35 GTR VR38DETT? I can't find any information on anyone having done this so does anyone on here know anything about doing this? I've heard good things about the injector, I'm just wondering what issues i may encounter. Thanks
I'm not sure if the rb20 is the same, but for the 25 you need a neo fuel rail and injector harness and you are good to go
Hi, They wont go straight into the RB20 rail. I ran an RB20 engine in my R32, then changed to an RB25 Neo engine so have experienced injector changes on both engines. For the RB20 I dropped the injectors from my RB26 GTR straight in and just had to make a loom to wire in the ballast resistor. I have now fitted VR38DETT injectors into my Neo engine and they were a straight fit but completely different size to the RB20/26 injectors so as mentioned above if you get a Neo rail then they fit straight into that. Hope this helps, Edward.
