VW Caddy Rabbit Drift Build
Thread in 'Project Cars and Builds Threads' started by Draklore, Jan 12, 2013.
  1. Draklore
    Draklore Member
    Hello Driftworks members :)
    to start my name is Shane Drake, I currently am stationed in GA, at Robins AFB.
    I have been an enthusiast in the VW/Audi community for some years now and own a featured Audi A4
    With a ton of work done-
    (On the left)
    Anyways, on to the caddy, I bought it a couple years ago just as a fun little project truck.. But being FWD and having around 40HP from the factory just wasn't enough to satisfy my needs.
    heres how it was when I got it:
    Over a year it transformed to this:
    (lame pic I know)
    Anyways, The truck was great but had some electrical issues and I started to really take an interest back into drifting, which I hadn't practiced since highschool.
    This prompted me to start thinking about what kind of crazy swaps I could pull off:
  2. Draklore
    Draklore Member
    Ok so on a whim and with my old iPhone 4 in hand I drove two hours from my house and traded the old phone for a 5.4 triton motor from a 2003 F-150. (260HP-350TQ)
    Quite happy with my trade :)
    And then I broke down haha
    The tired truck motor probably realizing its soon to be fate:
    But I finally made it home:
    And started stripping down the bay:
    Starting quite the ambitious project seeing how you're not even allowed to change your oil on base...
    The old heart:
    Now at first I was thinking I would easily fabricate mounts and a tunnel ect... But then realized that would be a ton of work.. But for the time being I stripped the bay thinking I would use it
    Just having fun:
    Bringing home some new tools:
    Ok at a certain point I realized that I would need a donor car with a modular motor... So for 500$ I bought this running 94 Ford Thunderbird with 80k
    Started stripping it down:
    #2 Draklore, Jan 12, 2013
  3. Draklore
    Draklore Member
    The 4.6 and 4R70W out of it:
    Here's my influence :)
    Everything on the TBird covered in "GA Clay"
    At the same time as the swap I would be doing a Euro "round" headlight conversion, which requires all new fenders and panels
    Stripping out the TBird interior:
    Then started working on the 5.4 Triton:
    Ac delete pulley:
    Test fitting the new front:
    Stole the 4.6 intake manifold, for its shorter height and TB location:
    Which requires these adapter plates for the 5.4:
    Running into fitment issues with the EGR:
    Who needs it:
    Swapping on the shorter 4.6 pan and sump:
    Starting on the wiring:
    #3 Draklore, Jan 12, 2013
  4. Hazzles
    Hazzles Member
    Interesting! The T-Bird looks kinda cool as it is.
  5. Stavros
    Stavros Active Member
    Cool, hope it goes well.
    There was a red RWD CA18DET engine VW Caddy at Gatebil when I went a few years ago.
  6. Draklore
    Draklore Member
    New headlights:
    Plugs:
    Now at a certain point I realized that the amount of work required to fabricate a new tunnel, firewall and front clip would be extraordinary... So here is the route I decided to take, which is actually the same method used by the Swedish Caddy 1Jz swap:
    Point of no return:
    OEM 3 piece grille arrives :)
    And now to work on the TBird-
    And to give you an idea of how
    Crazy I am:
    The plan:
    And a stop to the local steel mill for 80' of 1 3/4" .095 DOM tube-
    Tubing roller=fail
    Now before you proceed, this is not going to be entered into competitions, just a fun hobby build, the "Cage" is meant for structural rigidity, and a fun little project, I am in no way saying the cage I make meets or
    Would ever pass any tech inspection, and if I intended for it to, I would have had it built by someone who knows the regulations and has years of experience.
    So, now that is out of the way. I made modifications in a pipe bender and filled the tube with sand to prevent kinks int the bends.
    I am vet happy with my results :)
    To show you the idea behind the modification:
  7. Draklore
    Draklore Member
    Sealed with sand
    Ugly but functional:
    I have a tubing notcher but ended up not using it:
    DIY sheet metal break:
    More fitting:
    Originally going to use these B7 seats... Untill I realized they wouldn't fit with the door bars :/
    I had to make this steering column:
    Ford hub:
    Wiring support:
    MSD goodies:
    From template to reality:
    Skinning and framing:
    Original hood hinges:
  8. Draklore
    Draklore Member
    The front clip welded together to create an easy serviceability:
    Me going blind helping my daughter :)
    Door bar fabrication:
    Corey approves:
    COULD IT BE:
    In the sun :)
    And back out already haha:
    Some mocking up:
    Stock pedals for now:
    Stock location the motor sits closer to the PS tower.
    More fitting:
    Going for a good lift like so:
    Well I meant to pick up an 8.8 and ended up with this 7.5 from a V6 mustang:
    Rebuilding it:
    Stock gears for now, probably going 4.56 or an 8.8 later:
  9. Draklore
    Draklore Member
    A new unblocked PS vent for more airflow:
    The rabbit hollow axle next to the ford. Rember the caddy came FED!
    Cut off the stock locators
    The leaf springs ARE TEMPORARY. Until I can mock up a real suspension:
    Cobra R (Saleen) Wheels on 10" wide
    The width without rotors on:
    The plans are for a Lincoln Locker, when that blows we will see :D
    Made a faint line with the help of my wife;":
    Made this:
    After making one I copied the template:
    Mustang front hubs:
    Just tacked on for the moment:
    And starting on the fronts:
    Yah yah I can hear it now:
    Moog
    And that's the progress, I started the build mid November!!!
    Been a lot
    Of progress and fun so far. Shouldn't be long untill it's finished :)
    Thanks for comments and questions welcome
  10. Draklore
    Draklore Member
    Haha it did, some redneck really enjoyed that thing :)
    That's awesome, there is a rear engine caddy here as well, that was at Sowo12, it was partially responsible for this build, but his was a
    Pretty weak motor. I wanted to do something never done before :)
  11. Draklore
    Draklore Member
    Mustang hubs on:
    Mustang slotted rotors ordered for the front and rear, rear GT calipers ordered.
    Mustang Performance Radiator ordered, and 2X12" fans
    Threw on the wheels... Really really needing those smaller tires!
    I might machine down the wheels for a bit of a deeper offset. Looks like I have a few inches to play with before the caliper, or spindle are in danger of contact.
    Cheers and goodnight
  12. Magic21
    Magic21 Active Member
    great work there mate, love the leaf blower :)
  13. Stavros
    Seriously fucking awesome work. Love it
  14. 93s13nick
    93s13nick Member
    love it, always wanted to RWD a caddy with a big V8 in it :)
  15. Dantagonist
    Dantagonist Member
    Wow, I seriously didn't think that was going to get in there. Great job!
  16. xxcammichaelxx
    looks so sick! i love it
  17. JoeS13
    JoeS13 Member
    fair fucking play
  18. PikeyMike
    PikeyMike Member
    Fucking Hero.
  19. Draklore
    Draklore Member
    Thanks guys :)
    Today I got he driveshaft out of the TBird.
    10" too long.
    Once I get the wiring harness out I can tow away the shell
  20. Draklore
    Draklore Member
