Welded diff on Daily driver
Thread in 'Technical Questions' started by pieface, Feb 17, 2011.
  1. pieface
    pieface Go!Go!Auto
    The Worcestershire Nordschleife
    Right, I've just done a search and nothings come up so thought I would start this topic.
    I'm considering welding my diff on the S13, and I'm just after some advice of what, if anything, else should be replaced/checked.
    I know that I need to check, and possibly replace, the rear mounts/bushes. And I also read about Locking collars.
    Also, what are the effects of having a welded diff on the car.
    Do's, don't's, etc?
    Any help and advice would be brilliant.
    Cheers in advance,
    Pieface :thumbs:
  2. Kiwi-Richy
    Kiwi-Richy Member
    mhmm i dunno if its road legal over there for a lock but id heard about putting rubber shards in a diff so that when it heats up it locks up and when its cold its just open but theres porb a reason why people don't do more of it
  3. Shorty
    Shorty Member
    Sunny Norfolk.
    A welded diff will obviously put more strain on certain components in the drive train, would be worth checking things like subframe mounts for excess slop and bear in mind it will develop more of an appetite for rubber on the back...
    As for do's and dont's of a welder, there aren't raelly any.. can be a bit of a headturner at slow speeds and parking, but i find that under normal "spirited" road use mine gives better drive out of the corners compared to an open diff.. unless it's just me!? :smash:
    just be prepared for the sterring to feel maybe a little bit heavier until you get used to it, and the self centering action will be a lot more pronounced :thumbs:
  4. s14-jay
    s14-jay Active Member
    Nottingham
    mate, just weld it up. rubber shards?? wtf dont play about like that just weld it or shim it up. i used a welder in my daily for a goof half a year before i sold it for my next car. it was a 99 s14a and other than it skiping the inside wheel and shaking the car with stiff suspension when on full lock going slowly, it was completely fine. didnt change anything else, didnt look at replacing anything else. just replace what breaks if it even does. "if it aint broke dont fix it"
  5. pieface
    pieface Go!Go!Auto
    Anyone else got any input? Clarkey etc??
  6. TnF
    TnF Member
    Bath, UK
    welded diff is only for drift and drag strip...when the car steers the wheels rotate at different speeds...with a welded diff it will force them to move at the same speed, *cking up tires and suspension...i would not recommend at all(and as for safety is pretty dangerous for daily driving...that's why is also illegal)
  7. OptiBull
    OptiBull > > > > > > > > > >
    South West
    What the hell? Your chatting bollox
    You too are talking crap!
    Dear OP, this topic has been covered lots of times. Do another search. Use common sence and you will be fine.
  8. Skidder166
    Skidder166 Member
    What your saying is true.
    However its not a serious as you make out. i drive mine daily with a welded diff. Just take it easy in the wet and youll be fine.
    It definatly promted understeer in the car espically in the wet when driving, the fixed rear wheels try to force the front wheels in a straight line even when your turning!
    However massive fun in the rain if your intending to go sideways, obviously not just the rain however rain = cheap skid. Miniumal tyre wear.
  9. zeppelin101
    zeppelin101 Member
    Leicester
    There must be close to 100 thread asking this question already.
  10. PJ-R
    PJ-R Member
    Chippenham
    i thought this thread was a joke lol
  11. wst
    wst Member
    Every other thread ended with "Man up and just do it". It's not illegal, it will make a bit of noise at slow speed (so do LSDs anyway), it will wear tyres (but you're welding with intent to skid, tyre wear isn't an argument, you're in the wrong sport if you think it is) and other transmission components a bit quicker, it will understeer but it'll also drift better.
    Pros: Drifting
    Cons: Noise... if you even care about that.
  12. Dex
    Dex kut!
    Clogsville
    i wouldnt do it, its scary and VERY dangerous
  13. Simons13
    Simons13 Member
    Welwyn Hertfordshire
    Just do it, It really aint that bad!
  14. diamondsink
    diamondsink Kyouto Drift
    Kyouto HQ, Bristol
    Someone please make a sticky of a decent welded diff thread!!!!!!!!!!!!!!!!!!!!!!!!!!!
  15. Pipdub
    Pipdub Member
    Is there a sticky on this somewhere?
  16. Gavwan
    Gavwan Back to Black
    Essex
    No, we have a search button instead -suprisingly easy to use too
    welders don't kill cars, crap drivers do ;)
  17. RXsteve
    RXsteve Member
    Taunton, Zummerset
    Surley its not half term?!?!
    Here let me help you :-
    Here and also Here now get to the garage and warm the welder up :dw:
  18. cefiro_drifta
    cefiro_drifta Mad pointing Munky
    +1 welded diffs are know for mass rapage
    like genocide but it will be rapocide :eek:
  19. Dex
    Dex kut!
    Clogsville
    ye and i just swapped my daily with a welder for a old volvo, turns out, that has a welder aswell FFS. someone want to buy it? im scared of driving it
  20. sx slider
    sx slider Member
    +2 i heard that if you drive on the road with a welded diff it makes old lady's start to frigg off.
