What brakes to use on JZX100 non-turbo?
Thread in 'Technical Questions' started by HexMe, Oct 12, 2022.
  1. HexMe
    HexMe New Member
    Hi guys,
    Could someone with experience shine some light on this please? I can't find a concrete answer anywhere, so could anyone confirm what brake discs & pads go on 1999 Mark II JZX100 (1JZ-GE)?
    It's a nightmare to find what fits. Any cross-compatibility with 1JZ-GTE cars or some early Lexuses? What other parts would be compatible?
  2. Beefy
    Beefy New Member
    Should be compatible with IS200 brakes IIRC. Worth checking thouhgh.
  3. HexMe
    HexMe New Member
    Thanks. I have managed to find OEM part numbers and then search autodoc for OE equivalent parts. Someone also said that IS300 calipers bolt right onto the stock caliper carrier brackets so I could run IS300 discs & pads.
    Anyway the OEM part numbers for 1JZ-GE JZX100 are:
    Front Brake Pads - OE: 04465-30080
    Front Brake Disc - OE: 43512-22220
    Rear Brake Pads - OE
    : 04466-30140
    Rear Brake Disc - OE: 42431-22180
