What clutch 325 m50 welded diff
Thread in 'Technical Questions' started by Stuburger, Nov 21, 2015.
  1. Stuburger
    Stuburger New Member
    Hi guys
    ive just bought an e36 325i 1991 m50 non vanoss engine
    todays job was fitted coilovers all round and welded the diff!!
    been out in it tonight to give it a try gave it some serious abuse and clutch slips when i kick it in second and ive got back and the smell coming from the clutch was so bad it made me feel sick!!!
    What clutch setup are you guys running thats suitable for serious abuse on stock power with welded diff??
  2. Bolf
    Bolf Resident Nut Job.
    PE6
    get rid of dual mass flywheel in favour for a single mass , then stick a decent branded clutch in .
  3. Stuburger
    Theres a few kits on ebay like this which come with a single mass are these any good or will they be chocolate
  4. Stuburger
  5. pecs
    pecs Member
    St Athan / Wrexham
    C G Motorsport are very good yes.
  6. Andy318ti
    Andy318ti Active Member
    Edinburgh-ish
    You only need a standard clutch for standard power.
  7. Stuburger
    Whys it slipping when kicking it in second and stinking then andy
  8. Andy318ti
    Edinburgh-ish
    How many miles has your car done?
  9. Stuburger
    89,000 miles
  10. Andy318ti
    Edinburgh-ish
    89000 unknown miles. Might of had a replacment with a cheap shit item. A luk clutch kit will be suffice.
    If you want rid of dual mass either machine an m20 flywheel and get a m20 clutch with e21 release bearing. Or buy an aftermarket one for the engine.
  11. Stuburger
    Ok cheers andy
  12. ERTmotorsport
    ERTmotorsport Member
    Fife
    Good quality oem clutch is more than adequate for standard power, LUK or Valeo and you should be all good
  13. Stuburger
    I got a quote from a bmw performance specialist today who have told me standard clutch wont last in a car used primarily for drifting/clutch kicking so ordering up the cg motorsport kit
  14. ben-yates
    ben-yates Member
  15. Stuburger
    Cool cheers for that looks good
  16. Andy318ti
    Edinburgh-ish
    Listen to a bmw specialist over guys that skid 6pot bm's.
    Your throwing away money.
  17. pecs
    pecs Member
    St Athan / Wrexham
  18. ben-yates
    ben-yates Member
    It looks identical to the one in driftworks shop to be honest, think I may bite the bullet and get one, competition clutches seems a reputable brand so can't see it being too bad?
  19. Stuburger
    Im going to the pod nxt wed for a days drifting ill see how the clutch holds up there again i am a beginner and the slipping and smell quite likely also could be bad tecnique
  20. Stuburger
    Def dont need uprated clutch [emoji24]
