What diffs come with a range of ratios between 3.00 and 4.00, and can cope with 600+ Nm?
Thread in 'Technical Questions' started by hooblah, Dec 4, 2019.
  1. hooblah
    hooblah New Member
    I'm looking for a diff that has a range of ratios between 3.00 and 4.00. Also something available with lsd or can be fitted with an aftermarket lsd. It will be running somewhere in the region of 600Nm.
    The only thing that i've found that meets the criteria is a Z33 diff. Looking for other suggestions. Thanks!
  2. Pauly-C
    Pauly-C Member
    R33/34 gtr or a chaser setup
  3. stevieturbo
    stevieturbo Member
    Norn Iron
    Ford 8.8 ? Most BMW M series, Toyota Supra, Nissan 350 etc ? GM 12 bolt ? R200 Nissan ? Probably a few more.
  4. Bolf
    Bolf Resident Nut Job.
    PE6
    BMW 210mm , I have a 3.62 m5 e39 one with brand new 150nm LSD if you decide on this format.
