What do people take fans from? . .
Thread in 'Technical Questions' started by VAG-Slag, Mar 27, 2019.
  1. VAG-Slag
    VAG-Slag Member
    I've taken the viscous fan off my Audi S4 b5 and looking to put a fan on a switch in it's place...
    Need something powerful and also thin as there's not much space to play with... Got a fair bit of space for a wide fan though so anything 12-14" should be okay...
    Are there any go-to cars I might find in my local scrap yard which are known for having good fans?
  2. ross3k
    ross3k New Member
    Ireland
    Ive heard Mondeo electric fans mentioned a few times, not sure on years though.
  3. Andy318ti
    Andy318ti Active Member
    Edinburgh-ish
    I use vectra with no issues, I don't think it'll fit in your situation.
    Can you run the viscous? They're definitely the best option if you can.
    If not go scrappy hunting and see, most oe fans are up to scratch
  4. VAG-Slag
    VAG-Slag Member
    Reducing rotational inertia is always a good thing... Also, viscous is fine when you screaming round at 7000 rpm but once you're idling in the pit I've found airflow isn't sufficient and always end up popping my expansion cap in the pit even though coolant temps were fine on track.
    Didn't manage to get to the scrappy this weekend but will go on the hunt for a Vectra or Mondeo fan soon...
    Cheers guys!
  5. mad.matt
    mad.matt Well-Known Member
    Alloa. Scotland
    Mondeo, Jag V6 I'm sure was mentioned before (probably the same part)
  6. KiX
    KiX New Member
    Europe
    Try with Mishimoto ;) i'm have it on my 318is
  7. BenRice
    BenRice Well-Known Member
    New Zealand
    Anything FWD with an east-west V6 are worth looking at tbh, hence why the Mondeo is such a go-to
  8. chopaholic
    chopaholic Well-Known Member
    Northallerton
    Keep the viscous.
  9. jon07043278
    jon07043278 Well-Known Member
    North Wales
    Mondeo fans as stated above. Need a big old relay and fuse.
