Since fitting a welded diff, the back of my car is getting saggier and saggier... What bushes do I need to tighten it up a shedload? The front's pretty sloppy too, so do you do anything that would help there? I've done a 5-stud conversion too, so it's not all S13 bits now, if that makes a difference. Do you do wheel nuts? I'm running 25mm spacers all round and they have a Ford thread on them, the nuts I've got are crap and badly need replacing... Do you do some sexy, super-strong lightweight ones in a Ford fitment? Oh, I'm ready to order the latest Option DVD too now EDIT : Oh yeah, do you do fire extinguishers?
Greg, the subframe bushes make quite a big difference, especially on the S13 where the front pair are filled with goop Then you've got the arm bushes, it depends if you've got adjustable arms as to how many you need. Solid diff bushes are on the way, but will be a little while. They won't be for the faint hearted due to the amount of noise they transfer into the car, but if you want it supertight..... Front arm bushes are proving a little elusive at the moment, but adjustable tension rods will help quite a lot. 5-stud? no worries, it's all the same Wheel nuts, we can get standard ones at around £1.50 each, but steer away from the lightweight 'race look' nuts as they tend to thread really easily and when you're swapping wheels as much as we do, they just turn out to be a pain JDM Option Vol 20 rocks We've stocked up on that so no worries there, plenty left Fire extinguishers, we can get all sorts within a day or 2, but were waiting to hear the D1GB safety regs before stocking them ourselves. Once we know what the recommendations are, we'll work out the best option and bulk buy them to get you guys a decent price Cheers
Top answerage I don't have any adjustable stuff on the back at the moment, so I'll need a set of 4 subframe bushes, 4 x rear lower arm bushes and 10 x other rear arm bushes. That should tighten up the back a lot? Also need a set of adjustable tension rods for the front - I can only see S14/S15 ones in the shop though? Finally, will need 20 x wheel nuts in a Ford fitment... Can you get slimline ones? I don't want twat my alloys about with a brace everytime I swap wheels Oh, and a copy of Option V20 Have I listed everything right? If so, I'll start adding it all to my basket and seeing how much it's going to hurt me I'll leave the other stuff till you have it in stock.
Oh yeah, I nearly forgot, I want a little URL sticker doing... Not sure where it'll go, what size or what I want it to look like yet though Can you cut out any font (if I supply it)?
Only S13 tension rods we have on the shelf are the Tein ones. We're on the case with some cheaper ones, I'll chase those up today and report back Wheelnuts, I'm pretty sure we can get 17mm ones Stickers are no problem. We can cut any font
How long will the nuts take to get in? Can you do something like this : In say 15cm long? How much for 4? 2 normal, 2 reversed?
I've just seen the tension arms... Going to have to leave those for a bit, I'm not that flush yet The thermostatic sandwich plates you do, have they got any take offs on them for oil pressure/temp gauges?
Tein tension rods are £199.75, details are here: http://www.driftworks.co.uk/catalog/product_info.php?pName=tein-pillowball-tension-rods-nissan-fitment Wheel nuts, I can sort out whenever you like Stickers, 15cm is going to be small.... can you get us the red and black bits as separate files or seperate photoshop layers? You'd be looking at around £25 for the 4 of them or £35 for 8
thermostatic sandwich plates don't include gauge takeoffs, we're trying to find a better solution for that...
OK then, I've added all the bushes to my basket - how do I add the wheel nuts? Apparently the sticker above isn't subtle enough for the 2nd car it's going on, so back to the drawing board - any ideas? Maybe involving the funky frosted vinyl? I can ouput any bit of the logo seperately - might just have it in text though, I imagine it'll all look a bit shit otherwise I'm ready to order bushes/dvd/nuts though
Matt black or frosted stickers won't be a problem, depends what colour they're going onto though as to how subtle they'll look.... Wheelnuts are (off the top of my head) £1.50 each, but they're going to be reasonably heavy so it'll be an extra couple of quid for postage. If you add a 55cm custom stickers item and a pack of cable ties to your order that'll work out perfectly. Then just jot down in the custom order box what wheel nuts you want
any news on these cheaper tension rods ? Cause the front of my S13 is going bonkebonkeklonkeklonk. sounds really frightening
no news yet I'm afraid dude, we're working on it, but we're not happy with the quality of some of the cheaper items we've seen so far. If it comes down to it, we'll get our own made
