Wheel hop
Thread in 'Technical Questions' started by BrevS14, Jan 20, 2019.
  1. BrevS14
    BrevS14 New Member
    Ireland
    My s14 has always suffered from a bit of wheel hop,as we all like to "throw it out sideways" sometimes is the best way to describe it,so let up the clutch wheels spin,out sideways and as it straightens up wheels hop,into 2nd and aggresive wheel hop
    So what iv done over the years is stuff to what I thought would eliminate wheel hop
    Polybushed sub frame
    Polybushed diff
    Polybushed anti-rol bar and links
    Hardrace caster,camber and toe arms
    Hardrace lower control arms
    Polybushed hubs
    Running cs2 coilovers with polybush
    Everything fitted was new
    Any suggestions? No bother actually drifting
    Thanks
  2. BenRice
    BenRice Well-Known Member
    Mt Maunganui, New Zealand
    Are you running any preload on your rear springs? And what damper settings?
  3. oscar
    oscar Member
    Reduce the rebound setting on your rear dampers and be happy...
  4. BrevS14
    BrevS14 New Member
    Ireland
    Coilovers were setup for drifting when I bought them,had one event done! But I had same issue with the previous coilovers! Only other option is change the output shafts
  5. oscar
    oscar Member
    Did you buy the coilovers because you needed adjustability of the damping or because you think they look cool?
    The people in the know eliminated this issue in the 1960's.....
    #5 oscar, Jan 23, 2019
  6. BrevS14
    BrevS14 New Member
    Ireland
    Do you feel better about yourself now,feeling more manly after that comment,let the adults talk now
    Thanks for the advice lads,just never messed with the setting in them bar ride height seeing as they were set up and used before I bought them
  7. oscar
    oscar Member
    None so deaf as those that refuse to listen.
    • Funny Funny x 1
  8. Metaldan
    Metaldan New Member
    Germany
    Unfortunately, apart from being super stuck up, this reply is very far from the truth. Modern unmodded BMWs will wheelhop like crazy in the rain. Just search wheel hop on google, there are many examples. Did anyone else come across a solution for this exceptionally annoying problem?
