Which manual gearbox fits an Aristo 2jzgte?
Thread in 'Technical Questions' started by tw22, Aug 2, 2008.
  1. tw22
    tw22 Member
    Hi guys
    I recently took delivery of some cars and one of them is a JZ147 Aristo with a 2jzgte engine. Unfortunately it is an automatic.
    My question now is which gearbox will fit in there with as less mods as possible?
    Thanks
  2. garethr
    V160 / V161 Getrag 6-speed from a Mk4 Supra JZA80.
    R154 5-speed from a Mk3 Supra MA70 3-litre turbo (needs a JZ bellhousing)
    R154 5-speed from a 1JZ-GTE engined Soarer JZZ30 or Mk3 Supra JZA70 or Chaser/Mark II/Cresta JZX90/JZX100/JZX110.
    W58 5-speed from a Mk4 Supra non-turbo.
    W58 from a Mk3 Supra MA70 3-litre non-turbo (needs a JZ bellhousing).
    The W58 reputedly breaks with anything more than a moderate power increase.
    May have to extend the gearchange mechanism to move the lever back on the 5-speeds.
    American companies like Marlin Crawler for parts to strengthen the 5-speeds.
    I doubt if any of the above is easier to use for a conversion.
  3. Kenji
    Kenji Active Member
    W58 is cheap as chips. Unfortunatly also as fragile as chips.
    R154 costs an arm and a leg, but can cope with double the standard power easily.
    Getrag 6 speed costs an arm, a leg and a signed contract with some shady Rumanian criminals, but that 'box can take almost anything you throw at it powerwise.
    I've got a auto-to-manual converted 1JZ, with a R154, and love it to bits. Do it!!! :D
  4. tw22
    tw22 Member
    So I guess an R154 from an 1jzgte equipped car should do the job.
    Will there be some mods needed on the rear diff or prop?
    Thanks for the help guys.
  5. YashioFactory
    YashioFactory Active Member
    did i read on here ther other day,
    that you can get R154 gearbox in toyota pick-ups?? like the Toyota Hilux??
  6. Bean Bandit
    Bean Bandit Swiss quality
    what your up to mate? ;) - if all fails i'll take the engine of you and will put it in my Soarer :D
  7. tw22
    tw22 Member
    @ Bean
    I have some cars in the buildup and one is an Aristo 2jzgte, unfortunately it is automatic. Didn't you see the pics?
    Which Pickup was this in then??
  8. garethr
    Don't think it was the R154. R150(F) and R151(F) IIRC. "F" = 4x4.
    Probably different ratios -- close ratio for the cars and wide ratio for the trucks.
  9. YashioFactory
    o yea.
    you can get 2 wheel drive pickups tho? not really into my Hilux, il look into tho! :)
  10. skyludeboy
    skyludeboy Guest
    what about clutch pedal and clutch master cylinder which car would that come from ??
  11. Mad Cas
    Mad Cas wrecked
    Lol the w58 is only fragile if you are putting 350+ hp through it and properly skidding all the time.
    You'll have more trouble with the clutch size and clamping power to be honest.
    I dunno where the rumour that its weak has come from, just internet BS. The R154 is stronger yes, but not loads stronger. Driving style also has a lot to do with it.
    Hands up who has broken a W58 on here? and what power did you have?
    F*ck it, hands up who has ever actually owned a car with one in?
    I'm still trying to kill mine with 220hp and no pilot bearing, its on its second standard clutch but its still going, and my driving style is not kind to driveline components.
  12. cefiro_drifta
    cefiro_drifta Mad pointing Munky
    w58 comes in the manual surfs/hiluxs and arent that weak as cas has stated and i have been in his car and felt how hot that transmission tunnel gets :wack:
  13. Bean Bandit
  14. tw22
    tw22 Member
    thanks guys
    So cheap version for now would be the w58.
  15. YashioFactory
    would asume W58 more easy to find aswell ?
    wouldnt asume they are flimsy, if they are running heavy duty Toyota Hilux?
    know a 2JZ is a bit of a handfull tho!
  16. DriftLexus
    DriftLexus BDC Scrutineer
    Pah...Fishtits
    i got mine brand new still boxed, all paperwork for.....£700:D
  17. skyludeboy
    skyludeboy Guest
    can you get any more for 700???
  18. DriftLexus
    i will speak with the part of toyota i got mine from, however......we shall have to see
  19. skyludeboy
    skyludeboy Guest
    thanks bud let me know
  20. tw22
    tw22 Member
    Dude if oyu can get the 6 speeder at that price then let me know asap.
