white,vertex,s15 spec R
Thread in 'Drift cars for sale' started by gaz_moose, Jul 14, 2013.
  1. gaz_moose
    gaz_moose .MTM.
    this car has fucking sold so stop sending me PM's fuck headsIm going to sell my lovely silvia.
    a brief bit of history about the car,
    It was imported in 2006 by the first owner as a totally standard car he drove around in it for a few months then the engine expired, he then parked it up in his rather nice garage and decided to rebuild it into a track car. the entire car was then taken apart and every piece bagged and labelled. this is where the work stopped and it sat dormant until I bought it and did all the work on it which can be found in my build thread.
    http://www.driftworks.com/forum/drift-car-projects-builds/175994-my-little-s15-project.html
    The spec is as follows,
    Front and Rear HSD coilovers that are not seized,blown fucked.
    Japspeed tension rods modded for extra wheel clearance
    Poly front anti roll bar bushes
    Poly rear anti roll bar bushes
    New rear anti roll bar drop links with poly bushes
    Poly rear subframe bushes
    Japspeed rear camber arms
    Driftworks traction rods
    Driftworks toe rods
    Alignment done at A-line in Dudley to my own spec.
    R32 GTR brake master cylinder
    R32 GTR front calipers
    296mm Brembo plain front discs
    Ferodo fast road brake pads front and back
    R32 GTR rear calipers
    Handbrake converted to drum setup shoes have loads of life in them
    297mm plain rear discs
    Brand new blueprint R33 handbrake cables
    brand new HEL braided black brake lines front and rear
    17x9.5 impul hoshino RS all round
    215 45 toyo t1r's on the front (like new)
    225 45 falken 452's on the rear bit less tread than the front
    Japspeed FMIC with the recirc bit cut off and welded over
    Blitz air filter
    Horsham stage 1A ecu
    Stainless turbo elbow
    Stainless downpipe with a savage centre bracket welded on.
    Nismo cat back exhaust
    Walbro fuel pump
    Engine loom stripped back and tucked
    Battery tray removed
    Battery relocated to boot
    Anderson connector wired and bolted right next to battery
    New high capacity exide battery fitted
    New welding earth cable used for relocation marked up yellow for regs.
    Air filter box brackets removed
    Surplus holes in engine bay welded up and smoothed
    Engine bay and surrounding area's painted in 2k RAL 7046
    ABS removed and all new brake lines and ends
    Front brake lines modded for extra wheel clearance
    Front chassis loom routed into engine bay
    Small front washer bottle fitted
    Front wheel arch liners fitted and modded for wheel clearance
    Front wheel arch seams flattened for wheel clearance
    Extra stick on sound deadening applied to boot floor/rear quarters/rear arches/roof/doors to dampen out road noise
    Inner sills/rear quarters/rear inner arches/rear pockets treated to anti corrosion stuff
    Underside/wheel arches etc.. fully stripped/rust treated/etch primed/2k painted and 3 tins of 3m underseal applied
    Lower arms/subframes/tension rod brackets sand blasted and painted chassis black (stuff used on trucks)
    rear arch seam flattened
    Bonnet badge hole welded up
    Rear spoiler holes welded up
    Bonnet hinges modded
    Entire of exterior painted 2k ford frozen white/inside doors/inside bootlid door jambs etc..
    EP vertex lang bodykit/rear bumper/sides screwed on/front cable tied on.
    well spec'd JVC black faced headunit.Amplifier lead already ran to the boot.
    Focal front door speakers
    Kenwood rear speakers
    JDM Slide out cubby hole/drinks holder fitted under stereo
    Real leather gear shifter gaiter made by the upholstery guy in the unit next door!
    Aftermarket steering wheel
    Passenger airbag removed
    the nicer red floor matts front and back in real good condition
    Non fucked wind deflectors on both sides!
    HID headlamps
    LED fog lamp in reverse lamp
    Ice white LED rear number plate lamps
    that's all that I can think of off the top of my head!!
    I have the BIMTA certificate and all the import papers along with a massive folder of other stuff
    I want £9000 and im not interested in part EX as I own 4 cars at the moment and get a lift to work and back.
    #1 gaz_moose, Jul 14, 2013
  2. gaz_moose
    gaz_moose .MTM.
    pictures taken today,its to hot sunny to wash/take pictures of cars but you get the idea.
    #2 gaz_moose, Jul 14, 2013
  3. gaz_moose
    gaz_moose .MTM.
  4. ashdadrummer
    ashdadrummer Member
    What's the price buddy?
  5. Mitch
    Mitch In moderation
    £9000.
    I've had a few S15's on the ramp at the unit and this one is the most solid by a mile.
  6. gaz_moose
    gaz_moose .MTM.
    cheers man, ive been under about 10 s15's now and this was one pretty clean before I restored it. guess its due to the fact that its been dry stored for like 6 years.
  7. gaz_moose
    gaz_moose .MTM.
    ..page 3 is good for tits but not for car sale's type bump..
  8. gaz_moose
    gaz_moose .MTM.
  9. bell
    bell Without patience
    knowing gaz the attention to detail on this car will bespot on, he built this car to be a good daily someone is getting a very good base or a really nice daily smoker.
    good luck with the sale dude.
  10. gaz_moose
    gaz_moose .MTM.
    i would hope it was a good base for a skid car!! seeing as it has awesome handling upgrades. the transformation would involve turning the dampers onto a more firmer setting to what they are on now.
  11. bell
    I'll be honest i could'nt be bothered to read the sale's pitch buddy, i knew i couldnt afford it but i also knew from seeing the car it was cool as polar bear urine. ;)
  12. gaz_moose
    gaz_moose .MTM.
    im only messing buddy.
  13. bell
    snap.
    good luck with the sale though buddy.
  14. gaz_moose
    gaz_moose .MTM.
    bump I guess
  15. gaz_moose
    gaz_moose .MTM.
    boom shakka lackka ding dong.
  16. gaz_moose
    gaz_moose .MTM.
    moar pictures as I know we all love pictures,,
  17. gaz_moose
    gaz_moose .MTM.
    sausage surprise!!
  18. Tony N
    Tony N Member
    Is that what Rolf Harris said? :D
    Someone should buy this car, it's fully awesome!
  19. gaz_moose
    gaz_moose .MTM.
    yeah him and ken barlow.
  20. gaz_moose
    gaz_moose .MTM.
    im not interested in swapping this for corsa's/fiats's etc..
