C-west demo s14, forged rb26 500hp PRICE DROP £8300 as if found a car i really want,no offers It's a fully forged 26 with twin gt2860 hybrids Bottom end built by rb Motorsport in 2007 but hasn't done many miles going by old mot's i was told this is the original car built by C-west and used as there demo car,but unfortunately I have no proof. Here's a link to the original one when it was a single turbo ƒfƒ‚ƒJ[FƒVƒ‹ƒrƒAS14 | ƒGƒAƒƒp[ƒc‚ÌŠJ”laA»‘¢‚È‚çC-WEST Apexi power FC and commander but running a manual boost controller Nissan crank rb26 New valve stem seals Crank balance Nismo big ends Nissan main bearings Tomei 1.2mm gasket Nismo thermostat Tomei con rods Tomei con rod bolts Os giken 86.5mm pistons Re bore block to 86.5mm Block surface skim Trust sump extension N1 water pump N1 oil pump HKS cams HKS cam gears HKS fuel rail HKS fuel regulator Greedy plugs Apexi intercooler Apexi down pipe Mishamato radiator Apexi induction kits 19 row oil cooler Gt28/60R hybrid turbos with s/s internals (r34 N1s with gt2860-5 compresser wheels) Blitz straight thro exhaust Os giken twin plate clutch (TS2CD) 555cc Injectors In tank fuel pump Swirl pot 044 external fuel pump Sfs hose kit Braided fuel lines Oil catch tank Greddy type R BOV Chassis Gts box 5speed Full c wide arch kit 17 inch alloys 11.5j on the rear. Apex coilovers* Tein tension and traction arms Apex toe and camber Apex subframe locking collars Cusco rear diff 2way Cusco roll cage Cusco struts Alcon front brakes,4 pot Rear 300zx brakes with brembo discs I have all the invoices from when it was bought in 2005 from CRD adding upto 19k. The car went through a full bottom end rebuild in 2007 from RB using some off the best parts available and has only done around 3-4k miles since. Dyno print out off 527hp at 1.16bar.the engine build is capable of much more and the turbos and clutch are good for around 640hp The car was originally mapped for just 0.95 bar and was only turned up on November and has hardly moved since. 5 months mot 5 months tax Bad points are Carbon wrap has been removed and needs re painted.ive started painting it red using plasti dip,the car would benefit from a good rub down and painted properly. My intentions is building a drift car so I'm not fussed about the paint. synchros are worn and need changed as they are crunching. Crunches going down from 5th to 4th,what I do is change from 5th to 3rd keeping the clutch in then to 4th as it doesn't crunch then.it goes in from 5th to 4th without a crunch if the cars going slow enough. very small water leak but ill try get that sorted asap. Needs new alternator as the voltage does drop a bit at idle and around high rpm Fuel pumps are hard wired so are very noisy,work perfect The exhaust is crazy loud so not ideal for everyday driving Needs bigger injectors as its running high duty but its still running safe afr The car is getting painted in red using plasti dip,front bumper,roof,boot,fuel cap will be in carbon wrap,bonnet is real carbon Any test/check can be done on the car if someone is seriously interested
This is how it looks just now,another few coats should do it,its not going to win any prizes for its paint work but its getting built as a drift car so this paint will do
Any part exchanges? There's only really 1 but that really needs a good rub down and thats where the front wing meets the skirt its smoothed in and the filler cracked slightly so I filled it in but I didn't rub it down very well,could easily be done but I've started painting it already,that's when I noticed it needs done better,its a very small bit.and the rest off the car would just need a quick sanding to prep it for painting. The car really does drive well,I have thought I've had a few other problems with it but they ended up being paranoia as usual and you can get any1 to check it over fully etc.
Yes it's a cool looking car with the performance to match,just hard to sell something like this that needs some work I suppose If found a car I really want so ill drop the price so I can hopefully buy it £8300 that must be a good price surely?
I think it's the looks of it man. If it were to have say a vertex kit, all painted and nice wheels it would probably sell quicker
