Will a skyline rear fit my 13??
Thread in 'Technical Questions' started by mrsilvia, Jan 31, 2012.
  1. mrsilvia
    mrsilvia Member
    Coventry
    I've bin diggin about in the shed an found a skyline rear subframe & arms I forgot I'd got. Is it any wider than my s13 one and wat do I need to fit it??
    Failin that wats on the Market apart from spacers to make the bak end wider. Already got 10 in wide rotas and spacrs
  2. Dori-points
    Dori-points Member
    Midlands
    I think you need some off set bushes?? Arms and hubs are same as an s13 (with exception to hi-cas) so I guess you'll get a 20mm wider track?? Dont Quote me on that though! Alternately - DW arms might give you a bit more width if you adjust them
    Out a little? I don't know at what point the drive shafts become too short though lol.
